Question about Electrolux EW1000i Front Load Washer
My electrolux washing machjne ewn14991w is showing an error E11 and EF4 any idea how to fix
4 Suggested Answers
rdrsp
  • 85 Answers
SOURCE: Error E145
the ecb ( electronic control board ) has detected a malfunction.
check all wiring to the ecb and replace if needed.
also try unplugging the machine for no less than 5 minutes to clear all codes to see if the problem is intermitent or not, hope this helps....
Posted on Oct 26, 2009
  • 174 Answers
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
How do you fix e11 code?
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Sep 06, 2014 | Electrolux Washing Machines
Electrolux error codes Ef4
Usually means tap closed or water pressure too low.
Dado
Sep 03, 2014 | Electrolux Washing Machines
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
Jul 23, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
Dec 20, 2010 | Washing Machines
Ewn 14991w washing machine door won't close
http://appliancejunk.com/forums/index.php?topic=2846.0
OK go to link, above scroll down to LAUNDRY, and download one of these "Generic" service manual, inside you have troubleshooting procedures and repair how to's. It is what us engineers use to repair.
I think you may find you will have to replace the door handle assembly, and switch, interlock. This is a common thing.
http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/EWN14991W-_A
Owners manual,
http://frigidaireservicetips.com/pdfs/493_LaundryCenterwithTumbleActionWasher.pdf
Generic service manual, troubleshooting and repair.
Apr 11, 2010 | Washing Machines
Electrolux EW1000i Front Load Washer Logo
150 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
