Question about Nintendo Wii Console
Wii remote controller
The problem i seem to have is with the B button on the back of the remote.
When you push it it will not allow you to swing the club in the tiger woods game and in the Mario at the Olympics when you press the B button it causes you to foul. Any ideas
  • susa785 Apr 25, 2008
    test
  • kmac5582 Dec 14, 2008
    our remotes wont Sinc why are they not working?
    its not even registering it? it we checked the batteries everything and they are good for some reason though they are not registering with the system???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
There might be a glith in the games mabey its the contraler you should get a new one to see if that works any better if not call tech support and ask them
Posted on Mar 30, 2008
SOURCE:
My new wii control only blinks
There is a little red button on the front of the wii by the sd card port. Open the door and push it. Now on the back of the wii controller in the battery compartment there is a red button push it. Now your controller and wii will sync. you could also push the 1&2 buttons at the same time after you push the red button on the front of the wii.
Aug 30, 2014 | Nintendo Wii Remote Controller
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
How do I use the red buttons on the Wii remote control and on the Wii hardware to get it to be used as #1 remote.The games I am playing require that one of the controllers need to be #1. I have been...
after you push the red buttons push the A button on the remote and that should make that remote #1 you only need to sync the remote once then you just push the A button when you turn the wii on I hope this helps if not rite back.
Feb 27, 2010 | Nintendo Wii Console
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
My wii remot can turn on and i can push a and b but the wii remote wont work when i play baceball or boling. for exampol my avatar wont swing the bat when i play baceball.
Make sure the batteries are not worn down. If the sensor bar is in really bright light it will not work. Close the curtains so there is not lots of sunlight. Unplug the sensor bar and plug it back in again. You could try to re synch the remote, open up the wii remote battery pack and press the red button at the top once. Then quickly press the red button on the inside of the SD Card flap on the wii. If this problem persists try to get a new remote, or better contact customer services if these solutions don't work. Info is in the Wii manual.
Apr 15, 2009 | Nintendo Wii Console
Second remote will not recognize the wii mario kart. Second remote will work with all other wii games, except for Mario Kart.
Had the same problem last night.... Turn off the wii system by unplugging , wait a couple of seconds and plug back in. Next, the front of the wii has a pocket that opens, there is a red button. Put the disc to mario kart in the wii once you see the federal regs push and hold the red button on the wii for 15 seconds then once this 15 seconds is up with the controllers battery case open push the red button to the original controller. All of lights will flash and then stop. Push the red button on the wii console again just once. Then push the red button on the second remote wait till all lights stop flashing push the red button on the console and now they should be married to the wii system. Hope this helps----do you know how to get the volume? We don't have any volume
Jan 24, 2009 | Nintendo Mario Kart (Wii) for Wii
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
Wii freezing up
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to Nintendo.com, click Support, and go to the Wii Troubleshooting section for more options.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Apr 01, 2008 | Nintendo Wii Console
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
One of the remote controls seems to be stuck
sounds like to have a stuck button try another remote.
Dec 28, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
76 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
