Question about Ovens
I have a Kenmore built in electric oven. Put foil on floor of oven and it is stuck. Can't get it off. It looks like the entire lining of the oven is one piece. Can you help ?
  • 4,070 Answers
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you to buy a new lining. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Posted on May 10, 2010
My electrolux oven is ruined because of a oven mat--is their any paint I can use to cover the floor of the oven so it look even?
no
ovens operate well outside any paint heat range and paint fumes will spoil what is cooking
there are 2 fixes
1--- new oven internals
2--new stove
Jan 06, 2018 | Electrolux 30" Built-In Double Electric...
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
Melted aluminum foil
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Good Luck!!
Thanks
Dec 15, 2008 | Kenmore 33169 Gas Single Oven
Tinfoil stuck to floor of convection oven
have you tried warming the oven up first on low temp and then gently applying a paint scaper
mr muscle have a good degreaser but it can be strong in fumes read the tin first
Aug 01, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
