Question about Clarion Car Audio DXZ845MC AM/FM CD/MP3/WMA Player/Digital Recorder
Looking for diagram to wire up clarion car stero as wires are no longer marked such as power,ground speakers etc
    President:
  • 676 Answers
The following diagram should help you. Good luck and please rate.
Posted on May 10, 2010
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
I need the wiring diagram for my dxz745mp stero
black is ground, red is positive, blue w/ white is remote turn on, yellow is 12v constant, blue is power antenna, orange is clock/illumination, the rest of the wires are your speakers, solid white + white w/ black stripe is -, and so on.
Mar 13, 2010 | Clarion DXZ745MP CD Player
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
No power in my clarion i check the fuse and the wires is ok
Check your remote wire. (should be a small blue one in between power and ground) You can also take a voltage meter to check that your CD player is sending the remote signal down the wire when it powers on. Make sure your ground wire is securely grounded to a good source. Make sure its not on a painted area, etc. Find a good bolt on the frame or body. If none of this helps, you can open the amp and look for bulged capacitors on the circuit board.
Oct 04, 2009 | Clarion SRV303 Car Subwoofer
I need to know the wiring diagram for a Clarion
RED 12 VOLTS SWITCHED
YELLOW UNSWITCHED 12 VOLTS
BLACK GROUND
BLUE REMOTE OUT
WHITE,GRAY,GREEN AND VIOLET PAIRS : SPEAKERS
Sep 20, 2009 | Clarion XMD2 CD Player
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
Jun 20, 2009 | Clarion XMD3
Clarion drx9375r
Ask your friend Donald, maybe he could help you....:)
Sep 25, 2008 | Clarion DRX9375R
Clarion radio wiring diagram
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
Car Audio & Video Logo
608 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
