Question about Falcon Kitchen Ranges
I have a flavel milano 1000 range cooker and the clock,conventional oven and grill are not working, fan assisted oven still works fine, can anyone solve my problem
3 Suggested Answers
  • 492 Answers
SOURCE: No power to digital clock on cooker or lower oven. Top oven and grill working fine. Please help! Thanks Kate
unplug and reset the clock. Could be a power surge at night. Reboot the curcuit board like yo do the computer...
Posted on Apr 29, 2009
SOURCE: Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Posted on Aug 13, 2009
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
Does anyone know where to order a thermal trip for a Flavel milano 100 cooker. The right hand oven has stopped working and I have been trying to find the spare part to no avail. Cheers
The following address has a list of sites that sell oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Toaster Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 03, 2008 | Kitchen Ranges
Flavel Milano 100
Hi all...
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Flavel 100 finesse problem
I have a Flevel 100 and wish I had checked out all the problems everyone is having first as I would never have bought it...what a waste of money...already replaced the element on it...the ordinary cooker died weeks ago...now the fan one has died leaving me with no means of cooking in an oven...this is going to the nearest dump as soon as I can get to the shop to buy a very cheap standin...Flavel I hope you are ashamed!
Apr 22, 2008 | Ovens
Kitchen Ranges Logo
83 people viewed this question
Top Falcon Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Falcon Kitchen Range Expert? Answer questions, earn points and help others
