Question about Panasonic Audio Players & Recorders
TV sound to Cinema system?????????????
I have purchased an LG 42" LCD TV ( LG-42LC55 )
I am having difficulty connecting the TV to my cinema system( Panasonic C-PT450EB-K )
Please could you advise how this would be made possible.
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Posted on Mar 31, 2008
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
131 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
