Homelite Mighty Lite Lawn Trimmer  Logo
Posted on May 10, 2010
Trimmer model # ut2004b trimlite---- difficult to start will not continue to run and slows down when cutting and ultimately stalls
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Apr 18, 2010
SOURCE: My Homelite trimlite trimmer will only run in the
Could be a dirty fuel filter or cracked fuel line. The filter is usually inside the tank. You should be able to take the cap off and turn the unit upside down and shake it so that the filter drops from the tank. If not then grab it with a pair of needle nose pliers. If changing the filter or replacing the lines doesn't work, the carburetor might need to be cleaned.
Anonymous
  • 11 Answers
  • Posted on May 05, 2010
SOURCE: Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Anonymous
  • 10865 Answers
  • Posted on Aug 02, 2010
SOURCE: Trimmer starts, but stall's out, and is sluggish
Get a can of starter fluid and an assistant. Start it up and spray some starter fluid into the air intake to make it run long enough to clear up the sluggishness. J.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Aug 21, 2010
SOURCE: Craftsman 5.5 amp electric trimmer.
Maybe the unit is overheating due to a lack of ventilation and it has been a very hot summer. Make sure that the intake vents on the unit are open and clean, free of grass, debris, dirt etc. Easy to clog up with all the stuff flying around when running.
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Oct 04, 2010
SOURCE: I have a Homelite Trimlite model UT20706 trimmer.
Here is a link to one of my Tips: www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
If you need more help, let me know.
Good Luck!
Jim
1helpful
Homelite trimlite engine runs but head does not spin
Sounds like the inner flex shaft has broken, slacken the tube up at the engine and pull the tube and shaft assemly away, pull the inner shaft out and inspect
1helpful
The trimmer starts and idles fine but when you attempt to rev it up to cut, it slows down and stalls.
check the fuel filter in the tank, check that the cap is free of debris in the vent hole, as its idling, and you try and increase the rpms' adjust the high run screw out a 1/8 turn at a time until it achieves the desired speed, Clean the air filter
1helpful
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
2helpful
No power
there is a little screen in the muffler these get stopped up some time remove it start engine if this works just clean it and replace it back ..
Sep 09, 2009 • Garden
1helpful
Where do I get a replacement screw for the muffler. Homelite Trimlite Model UT20760.
you can take your trimlite in to your local hardware store and match the screw right there in the store or go on line to homelite dealer to order. hope was some help
Jul 11, 2009 • Garden
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
