Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon mp500 will not print and shows a 6A00 error.
What does that error message specifically mean? There is no paper jam. But the ink carriage, which contains six cartridges, does not move automatically. How do I solve that? Do I need to go to another expert at FixYa who is familiar with this specific printer? i am not a facebook member.
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 10, 2010
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hello! I am using a printer PIXMA MP 500. When I am trying to print it's not possible and on the screen there is a message:Service error 6A00, with suggestion to cancel printing and turn the printer off...
Hi you can try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All the Best:Pineworks
Jan 11, 2010 | Canon Pixma MP500 All-In-One InkJet...
It shows Service Error 6A00, a message that shows up and the printer will not print. It has ink and paper and the correct printer driver. Help me fix it at home if possible. DATravland@aol.com or (352)...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printer wil not print there is a err 6a00
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
          To say in detail ERR 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.The offending item needs to be removed or the purge unit needs replacement.            The purge unit is a plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail. move it back and forth about 5 times, close everything up, and restart. Note the the purge unit is NOT the print head! to be more specific: Take out all the ink cartridge, push the cartridge holder back and forth and clean the inside without taking it apart.
            Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit. here goes, the purge unit.
Plz rate this solution.. thank you..
Apr 08, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00
Hi
Try this out
Solution 1:
Solution 2:
Solution 3:
Mar 01, 2009 | Canon Pixma MP500 All-In-One InkJet...
Receiving error message on display screen of mp500 code "6A00"
Hi
I think it the same code
Solution 1:
Solution 2:
Solution 3:
Jan 05, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error 6a00 in my mp500 pixma
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Pixma mp500
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 08, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
