Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
Posted on May 20, 2010
The beer froze in the chiller what could be the problem
The thermostat is stuck in the closed position if you noticed that the unit runs and runs and runs without cycling off sometimes. If it cycles, move the thermostat setting up in number (warmer). Make sure, if the unit is in your garage or otherwise not inside where it is warm, that the temp of the outside air isn't below freezing - coolers don't do warming and will not protect the beer from frigid atmospheric temps. Good luck.
Apr 20, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
I can't get my keg beer under 48 degrees, even at
clean all coils and fins and filter ...don't block exhaust with anything (should be no sugar left to ferment)
Aug 23, 2009 | Summit Commercial SBC-500 Beverage Cooler
Beer freezes
The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat.
Aug 17, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Too much foam
well you are right the CO2 is causing the foam you may need to replace the regulator on the tank it is most likely bypassing the bellows inside...as a temp fix you can shut down the co2 and bleed off the air then just crack open the tank to (hand) regulate the flow ..
Feb 16, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
429 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
