Question about Ronco Automatic Popeil Pasta Maker
I need the part that screws on the front to hold the dies
    Champion:
  • 287 Answers
I sell the parts and have them available on ebay or just go to ebay and ask someone with the pasta maker to buy a part only. My site is under the name exswissch.
Posted on Oct 01, 2010
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I get to the motor of this dryer? Do I need to get to it from the front of the dryer or the back?
On a rear control LG, from the front. Open door, remove two phillips screws at 4 and 7 O'clock positions, use putty knife to push in clips (2) holding top at front, swing top back, remove two phillips head screws holding front panel cabinet. Disconnect door switch and light plugs, tilt front panel forward and off bottom tabs, allowing sensor at bottom to be un-plugged, thus front panel now completely free of machine. 4 phillips screws hold front bulk head / front drum roller supports to cabinet. Lift up and off. Reach in and remove belt from tension pulley. Drum comes right out, allowing access to motor.
Jun 13, 2010 | LG DLG3788W Gas Dryer
One of the "bars" in the interior of the dryer drum is loose
The front panel needs to be removed before the top cover can be lifted and access the baffle screws for tightening. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
After my car battery died I needed to type in a 5-digit code to restart my radio. However, I do not have this code nor the serial number to figure out the code. I was told I needed to remove the radio to...
first remove the front console
there is a screw behind the ash tray
two more screws on two lower corner of the shift lever
remove the console
remove the screws hold the radio
Mar 05, 2010 | 1996 Honda Accord
Need to remove the front
there are two screws on the back of the lid take those off then slide the lid off remove the screws that hold down the control the the screws on the inside of the cabinet that hold the front panel in place once removed the panl will pop off
Sep 09, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Control panel buttons due not work
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics schmidtkeith1@yahoo.com
Aug 31, 2009 | Maytag 30" Built-In Single Electric Wall...
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Need to remove case of hotpoint wma 63
The drum comes out through the front on this one.Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band holding door seal & peel seal back.Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side &slide to right to remove being carefull with board & wiring.Remove screws holding top end of front then lift slightly &remove front.Remove back panel &take wiring off heating element & pump. Disconnect the pump hose at the drum end, disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
If you need any further assistance please post back
Good luck & thanks for using Fixya
Nov 27, 2008 | Hotpoint WMA64 Front Load Washer
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Aug 26, 2008 | Philips 190B6CB/27 19" LCD
Fix Loose Baffles
The two screws that hold the door door hinges and the two on the opposite side of the door opening hold the front panel in place. Once you remove the door and the other two screws the front panel should swing down to access the screws that hold down the top. But you may be able to reach the baffle screws once the front cover is removed.
Oct 30, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Ronco Automatic Popeil Pasta Maker Logo
119 people viewed this question
Top Ronco Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Ronco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
