Question about Olympus DS-2300 Digital Voice Recorder
Skipping of Sound Files
We seem to have problems with out sound file, we dictate as normal and send the sound files off to our typist for typing but when the letters are returned there are substantial paragraphs In which the typist has been unable to type as the sound file has skipped…this is happening with nearly every letter that
We receive back from our typist.
Is this a common error? Is this something in which the way the machine is set up, which can be changed?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Format card through the recorder should clear up most of the problem after you have downloaded the files
Posted on Oct 03, 2008
SOURCE:
I also cannot get the sound effects to work on my Windows 7 machine when playing 688i hunter killer game by sonaylists. This seems to be a wide spread problem. I'm wondering if there is a patch that...
This worked for me.
For the sound effects to work you'll need to download SC (Starcraft) Sound Edit Utility.
Open up the utility and then open up file Sfx.agg found on a standard installation here (hold the quotes) "C:\Program Files\Sonalysts Combat Simulations\688I\Sfx"
Select all the sound files and extract them and you are done. the sound files may end up in the compatibility files.
Sep 14, 2011 | EA - Electronic Arts 688: Hunter/Killer...
Windows Media Center keeps skipping certain files everytime I sync.
Does it tell you why the file was skipped? Normally this is because of two reasons. Either the file type is not supported or the file specifications ( name, location, extension, etc.) have changed so WMP cannot find the file to sync it.
I may help if I get more information.
Jan 02, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Lights up, makes skipping sound, wont show up on
Sadly, that skipping sound is most likely the sound of death for your external hard drive. The drive is composed of two or three disks, with read heads that hover incredibly close to the spinning disks. That skipping sound could be the head scratching the disk, leaving the hard drive useless. Your best bet is to contact the manufacturer and have it replaced as defective - if it's still warrantied.
Mar 09, 2010 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
How do I make a audio CD from my dictation machine
If you are already using your dictation machine then you don't need to install its software as its already installed. Now you only require Nero for burning files to CDs. You also require a CD writer installed on your pc. You shall know where your files are saved when you record through dictation machine. If you can't find the recorded files kindly comment back.
Feb 05, 2010 | Audio Players & Recorders
Unlocked Motorola phone can't do multimedia messages
i have the same problem but i cant send or recieve pictures,audio files,ect. and also i constantly have a message icon that will not go away
Aug 10, 2009 | Motorola Mobility W510 Mobile Phone
Cant find sound folder on mini sd card to add tones from computer
This menu displays music files saved in your phone and microSD card. 1. From idle mode, press and hold the OK Key [OK] to unlock the keypad, press the Left Soft Key [Menu], the Directional Key to select “Media Gallery”, then slide out the QWERTY keyboard and press 1. My Sounds. 2. Scroll through the downloaded or saved sounds to select the sound and press the OK Key [PLAY] to listen to the highlighted sound. To erase the selected sound, press the Left Soft Key [Erase], then press the Right Soft Key [Yes]. 3. Press the Right Soft Key [Options] to choose from the following: • Send by Picture Message: To send a MMS message. • Send Online Album: To upload selected sound to sound online server. • Send by Bluetooth: To send selected sound to another Bluetooth device. • Set As: Assigns the selected sound for specific tasks (Ringtone, Contact ID, Alert Tone). • Rename: Rename the selected sound. • Lock/Unlock: Select to lock or unlock the selected sound. • Move: To move the sound to another location. • Erase All: To erase all the sound files in your phone. • File Info: Displays information about the selected sound. Since you can’t Send or Move a DRM file, the Send/Move options will not appear when working with these type of files. With microSD card inserted, you can browse all folders and sound files saved in the microSD card by searching the Back folder . indicates that current file is stored in the external memory. indicates that current file is stored in the phone memory. indicates that you have sub directory for the current folder.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 02, 2009 | UTStarcom Blitz Cell Phone
Sounds skipping and missing in some areas on media player
Hey there,
Go to ur motherboard manufacturer web site
and type the Motherboard model no. in the search pane. Download the perspective driver of ur motherboard which also includes the sound driver.
Else, Go to google and type the model no of ur sound card as well as the firmware version. Download the driver with the compatibility with ur OS and then install it.
Gimme ur acknowledge by rating me.
Thanx.
Romy
Dec 23, 2008 | Microsoft Windows XP Media Center Edition...
Olympus ds-30 deleted file recovery
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
Sep 26, 2008 | Olympus DS-30 Digital Voice Recorder
Is it possible to stop recording without opening a new file?
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus DS-2300 Digital Voice Recorder Logo
98 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
