My Zanussi Aquacycle 1000 will not spin and the water will not pump out. I have cleaned the filter and the drum spins when switched to a wash cycle, but nothing happens when its time to spin and pump out! Any ideas? Best regards Vince Smith
  • 185 Answers
Check the lid switch
Posted on Mar 28, 2008
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Aquacycle 1000 f1045 spin dry fault
test the machine empty without clothes in it, if all is well then i think your problem may be the motor carbons, take them off and check for damage, make sure one of them has not spit down the middle, also look at the armature for signs of sparking,a worn armature or carbons will work fine at slow speeds
you haven't mentioned the carbons, its trying to spin so may not be the pcb
Oct 14, 2007 | Zanussi FJD1666W Front Load Washer
Washing Machines Logo
591 people viewed this question
Top Washing Machines Experts
