Question about GE WBSR3140DW Top Load Washer
GE top loading washer turns off by itself
GE washer will turn off in middle of cycle. It does it randomly at all times during a cycle. It seems that any type of movement will turn off washer. For example if the water pipes bang it turns off. If the load of laundry is uneven it turns off. If you bang down the lid it will turn off. I think it may be an electrical problem with the start button, but I don't want to put money for parts into it if I don't have to. It is a 5 year old machine and is used for at least 2-3 loads of laundry a day.
Thank in advance for any help!!
  • Joma Feb 06, 2012
    Did you ever find a solution to your washer problem? I have a 7 year-old top load GE WSERE526 doing the same thing. It does seem like it's an electrical problem since all lights on the control panel go off when the washer randomly shuts off.
  • Anonymous Mar 27, 2014
    Machine will randomly turn off and on by itself during a load
    President:
  • 3,113 Answers
How about a lid switch. Try pushing down on lid to restart.
Posted on May 10, 2010
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
May 23, 2010 | GE WJSR2070B Top Load Washer
It turns on and fills by itself. sometimes it
a bad water valve could cause this / if it leaking through . when the tub is full it will start itself and cycle . / also the control if bad would do this .. mm
Dec 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Mar 07, 2009 | GE WJRR4170E Top Load Washer
Washing machine stops when there is 19 minutes left!
you need to have a tech out to look at it it sounds like the motor isnt going into high spin and /or cutting out on over load this is a problem with the g/e's there is no filter on this machine all the lint is flushed down the drain
Jan 08, 2009 | GE WBSE2090A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
276 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
