Question about Kirby G4 Bagged Upright Vacuum
Power I own a Kirby G4 model and am interested in finding out the wattage of the motor. Regards Peter May
    Scholar:
  • 116 Answers
The motor wattage is 700watts @ 240volts ac and 3amps
Posted on Apr 19, 2008
  • 25 Answers
6.5 to 7.0 amps
Posted on Mar 28, 2008
  • drago640 Mar 31, 2008
    NOT SURE HOW THIS RESPONSE WAS INAPPROPRIATE
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Manual for a kirby g4
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2012 | Vacuums
I am looking for a service manual for my Kirby G4D vacumn.The number on the vacumn is 7941006690. Sounds like there is something caught in the motor or fan . I am not sure how to take the vacumn apart...
Ava B.
Aug 17, 2011 | Kirby G4 Bagged Upright Vacuum
Is there a motor reset button? power light lites up but no motor
Troubleshooting tips are found on page 51 of the G6 manual. This applies to most Kirby models.
This manual can be found at the below link.
http://ubermanuals.com/search/contentsearch/kirby
Mar 13, 2011 | Kirby G4 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby g4 tech drive, when plugged won't come on ,is it the motor or something else ?
Does anyone know if there is a reset button on the Kirby G4? And if there is where it is?
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Can't find owner's manual. need to use my kirby g4 to inflate an air mattress. help
Remove power head and bag from motor install pig nose attachment on front where powerhead goes install hose on back where bag attaches put inflator tool on hose
Jul 06, 2009 | Kirby Vacuums
G4 model is burning
May be the carbon brushes. DO NOT run the vacuum until you check them. If they are worn out, they can damage your armature and that is expensive to replace. Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Aug 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
75 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
