Question about Braun 8585 Electric Shaver
Loud rattling noise
Just starting making a loud rattling noise and seems to be vibrating more?
  • Braun Master
  • 1,610 Answers
Most likely, the drive unit needs replacing. You will find a drive unit at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To replace you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out
Posted on May 11, 2010
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud rattling noise that vibrates of oan on coming
check all things are tight like exhaust & fan etv & not rubbing
on anything
also look for wear marks from rubbing! shiny bits
Jul 18, 2009 | 2004 Jeep Grand Cherokee
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Vibrating noise
u may have food in pump u see sometimes it dose happen i have pop corn seeds in mine
Dec 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Engine vibration at start up
water pump by teh sound of it seal ok but bearing going
Nov 12, 2008 | 2002 Ford SVT Focus
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Braun 8585 Electric Shaver Logo
627 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
