Question about Toshiba TN55X81 55" Rear Projection Television
I have a tn55x81 that shuts off after only a few min. like its over heating or something...if you unplug and plug in again it will do the same thing. If it stays off for a few hours it will last a little longer maybe like 5 min. but still turns off by itself. what could be the problem?
  • 1 more comment
  • dernst488 May 10, 2010
    Thanks for the info. I'm pretty sure the timer wasn't on. I had reset all the settings on the TV. It seemed to stay on shorter the longer it had been on. I will clean all the dust off the boards and see if that helps. If not i'll play with the power switch to see if that changes anything. I will let you know if I have any problems after this...
  • dernst488 May 11, 2010
    Cleaned off all the dust of all the boards and still did not fix it. All the heat sinks are clean. Even tried to get to the power switch and dusted that off. Still didn't stay on. One thing I did try was to unplug a few connectors that had RED, GREEN, BLUE on them. (see pictures) First i tried unplugging them all and that seemed to work,but the colors and the picture where off. (kinda figured something would happen) BUT it stayed on!!. So then I turned it off plugged in the GREEN one and tried it again....Still stayed on. Turned off, plugged in the GREEN, and RED one....Didn't stay on. Turned off....plugged in the GREEN, and BLUE on Didn't stay on. Any Ideas???? This board is on the left side of the TV if your looking at it from behind. It's kind of on stilts.
  • dernst488 May 12, 2010
    I have tried this and did not work. I did try however to unplug some connectors on a board located on the laft side (if viewed from the rear) it is on stilts and has two big heat sinks on it. I had removed all three RED, GREEN, BLUE connectors and it had stayed on!! i then proceeded to power down and plug in one connector at a time. Powering down each time i added a connector. first time pluged in the GREEN only. It stayed on! Then GREEN, BLUE only and it stayed on. then I tried pluging in all GREEN, BLUE, RED. and it turned off by itself again. What could be the problem. Obviously the picture was off and blurry if one of the connectors was not plugged in. Please tell me what might be wrong with it....
  • 11,896 Answers
Could be overheated capacitor or a faulty power inverter. You can get an analog tester or ohmmeter and test the capacitors. And you can use a voltmeter to check the power inverter.
Posted on May 12, 2010
  • Toshiba Master
  • 6,993 Answers
firstly, check your TV settings and to confirm if the timer is on or not. The timer might be the reason your TV turns off frequently.
If the timer is not on, then the timer is not the cause of the problem.
There are two reasons why your TV keeps turning off, 1) could be the on/off button. The button my be popping of at interval, that is, it may have worn out and not hooking well. 2) could be over heating. The heat sink maybe dusty.
Either way, the solution is quite simple. The on/off button simply toggles a low voltage circuit that powers your TV. If it is dusty, it may complete the electrical circuit and send a false signal.
A heat sink may be dusty and unable to dissipate heat. Over temp protection may be switching the TV off.
Allow the TV cool, open the TV back cover and clean the dust off the circuit boards. You can use a paint brush to remove the dust from the TV board.
Good luck.
Posted on May 10, 2010
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
My Toshiba powers off every few mins and will not turn back on until i unplug the tv and plug it back in. Will only stay on for another few mins. The long its unplugged the longer it will stay on up to ten...
It sounds like you have a bad capacitor. When one is faulty, they will demonstrate this type of behavior. The issue is finding out which one. If you are not a skilled technician, this is a difficult task. I would recommend that you take it to a TV repair shop, and let them repair it, if you are unable to. The good thing is that the cost of a repair is significantly less expensive than a new TV.
Mar 22, 2011 | Televison & Video
My dell xps 200 shuts down and the power light flashes amber. I try turning it back on and it does not respond. I have to unplug it from the outlet wait a few seconds then plug it back in. After I do this...
You can try unplugging the PC, removing the RAM and re-seating it. It could also be a power supply issue, either too much for it to handle or it's not functioning correctly. My first suggestion would be unplugging hardware that's not needed for a week or so and see if it keeps happening with only the HDD plugged in. If it doesn't continue plug one thing in at a time until you find the culprit... although because it does run for a bit when you have the so called culprit, unplug it and plug something in its place, if it continues then you may have over powered your power supply and need to get something a bit larger.
You may also have issues with the PC over heating or fans not running correctly, make sure to check these items while your PC is turned on. (please be careful).
Mar 07, 2011 | Dell XPS 200 PC Desktop
I don't know if it's my linksys 5 port router or
Could be over heating let it cool meaning complete shut off unpluged 20 mins for all heat to removed. Then check how long it stays on. If it last more than a few mins it is over heating. You need to try to get all dust out of it and try it again. If this time the link is lost after a few mins or hours its was over heating. Also at this point it could be a bad component over heting and a new router is need.
This could be one of many problems good luck.
Sep 09, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Intermittent reminder beeper won't shut off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
May 24, 2009 | GE Advantium 120 Convection/Microwave Oven
2004 denali rear hvac
I had this same problem, With it running and heat and blower on full blast remove and unplug the rear faceplate for the rear heat.
Unplug for about a min.
Shut off engine.
Cycle the key 5 times.
Start engine.
Plug in the plug to the face plate.
For about a min. nothing will happen no heater no blower.
After the multiplex system refinds its address, the rear heat will then work again.
this worked for my 04 trailblazer.
Dec 21, 2008 | 2004 GMC Sierra Denali
Presario s6500nx stops loading at set up screen
sounds like you have board problems.
unplug everything from it first and see if this helps could be something you have plugged up could be bad too.
you will have to open box and look for damage and then one by one unplug something and then reboot to see what it might be.
Aug 03, 2008 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Toshiba TN55X81 55" Rear Projection Television Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
