Question about Microsoft Xbox 360 Console
Fault with xbox 360
One red light flashing + a message on the tv screen saying E 74
    Scholar:
  • 78 Answers
Hi
Disconnect and try reconnecting all wires, if this does not help then follow the steps mentioned in following link. But before I provide you the link, I would like to inform you that, it is Most likely that you will have to send your xbox console to the xbox customer support. But before that lets hope for the best and try the following.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907536&lcid=1033&category=hardware
and
http://support.microsoft.com/kb/941377/
You may also Use their step-by-step solution. Here is the link.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=frls
Here are links for customer support
For US
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
and
For outside US
http://www.xbox.com/support/contact
This solution is absolutely FREE. Please rate and give your feedback. Thanks :)
Posted on May 10, 2010
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
It's got 1 flashing red light and it says E 74 (xbox 360)
you need to have the x-clamp replacement done. or if it is still under warranty send it back to microsoft.
May 31, 2010 | Microsoft Xbox 360 Console
I have code error 74
Code E74 1 red light flashing and error message on screen right? It is the scaler chip, it happens because the scaler chip starts overheating. If you stop the heat build up on the chips then you should be fine.
You can send your Xbox 360 back in for repair or fix it yourself with a good Xbox 360 Repair guide
Oct 28, 2009 | Microsoft Xbox 360 Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
