Question about NEC Nefax 791 Plain Paper Laser Fax
NEC 791 error code 10 what is this? - NEC Nefax 791 Plain Paper Laser Fax
NEC V260XG temperature error. How to Stop??
check the thermostat; it appears that either the thermostat is not working properly, or is not set right or damaged
Apr 23, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
Printer Trouble error message on NEC DTH-16D-1(BK)
SAME PROBLEM:
Hello jlaverty,
Did you ever figure out how to fix this?
We just had a long power outage last night and our phone system wasn't accepting outside calls this morning. We reset it, which fixed the problem after 10 minutes or so of waiting.
The new mystery is why the admin phone is now flashing this "Printer Trouble" error message.
Thanks,
Brian
Apr 07, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I have a 1986 nec tv and have lost code book to reprogram my remote. i am using a universal rca remote but nothing seems to work. can you supply me with the correct code for my set. my nec tv is a...
Not anymore. go to a tv repair shop and look for an older universal or maybe an original. the new ones won't work on this old stuff. however it might be your I.R. receiver failed. but i have seen this quite a bit lately. if it is more than 10 yrs, old there is a problem with some mfg. codes. and nec doesn't make tv's anymore.
Jan 01, 2010 | Televison & Video
-5004: Ox80029c4a error. Have lost my NEC display monitor. Tried to install latest nVidia driver for my NEC Multisync LCD1970GX monitor. Driver did not fully install, and now I can't install a copy of the...
Error Code: -5004 : 0x80041f42
Error Information:
*C:\Program Files\Common Files\InstallShield\Professional\RunTime\11\50\Intel32\iKernel.dll
>inc\CoCreate.cpp (44)
>SetupDLL\SetupDLL.cpp (1405)
pAPP:Realtek High Definition Audio Driver
PVENDOR:Realtek Semiconductor Corp.
Oct 15, 2009 | Samsung HL-P6163W 61" TV
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Office Equipment & Supplies
Remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Jul 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Mar 17, 2008 | NEC LT30 Multimedia Projector
NEC Nefax 791 Plain Paper Laser Fax Logo
76 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
