Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Red-orange residue on bottom of pool - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • 623 Answers
Sounds like a bacteria growing. Have you shocked the pool water lately, and scrubbed the spots with a brush?
Posted on May 10, 2010
How do I know which sides to hook up the four sets of wires that go to the manifold on my Pentair mastertemp 250. Are they interchangeable? One purple set one red set one orange set one brown set.
Absolutely not, they are not interchangeable! Each set of wires, go to a specific sensor or switch. The opposite end of that wire goes to an electronic circuit board with specific logic. It is in constant communication and or waiting for communication/confirmation, from that specific switch or sensor, so that a specific action can be taken for a specific situation, all based on that specific sensor or switch that it is connected to. So therefore do not rearrange the wires.
purple wires usually go onto a pressure switch. Red wires will normally go on to the automatic gas shut off switch, or AFS.
there are usually two sets of two wires for the high limits, and they are colored orange. Because there are two high limits.
Brown wire, I'm not sure of? I don't remember any brown wires on a master temp. Is it possible that the brown wire that you see, has discolored and it was an orange wire, or a set of orange wires previously?
May 21, 2015 | Pentair 460732 MasterTemp Heater 250BTU ...
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have a residue at the bottom of my pool. It will not vaccum out just relocates. When the filter is running the water is white looking.
Sounds like you may have a torn pleat on your filter or may not be properly installed and sealing correctly???
Jul 21, 2011 | Intex Automatic Salt Water System for ...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Wiring My Pool Pump
that pump is probably prewired for 220volts. you will have to check the diagram for how to configure it to 110v. most motor can be converted to 110v. If you are not comfortable with reconfiguring, contact a service tech.
Sep 13, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
Owners manual lost
I have some similar swimming pool lights that are rechargeable. If my light, green means that the battery is ready for use, orange means that the battery is getting low, and red means that you need to recharge. I would assume that this is the same for yours (because mine is very similar). Hope this helps.
Jul 12, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
263 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
