Question about Xerox Office Equipment & Supplies
XEROX Document Center 440st. When I Copying LTR Paper 2sided Copy From Platen glass On LGL Paper, Massage In Screen Auto Rotation Is Not Possible And The matter In Second Side Of Copy Is Cut Or Rotate. Pls Give me Help On This In Assess #11 LOT NVM Adjustment 2-38 Auto rotation This Function Is Read Only What Can I Du????????????
    New Friend:
  • 44 Answers
In order to reduce/enlarge the image, try feeding the paper short edge from the cassete
Posted on May 14, 2010
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Changing Image Size
It may sound silly, but it may work. When you inlarge the LTR page, is it cut off? Try placing the page to be copied or enlarged on the copyboard glass going in the LTR-R direction.. Good Luck
Jun 23, 2010 | Canon imageRUNNER C2620 Color Copier
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Prints are only at 80%
make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
May 26, 2009 | Sharp AR-164 Copier
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
94 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
