Question about Grohe Chiara Neu Lavatory Centerset 32.362.AV
Water pressure has dropped off with pressurised water system
The water flow has dropped off even with pressurised water system on one of my hand basin mixer taps..
All other taps in the house are working well.
I would appreciate any solutions please, if it is washer needing replacement, how do I change it?
Regards\
Peter
  • 25 Answers
Hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
Posted on Jul 12, 2010
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
My pump, used to pressurise the water in the house, keeps coming on every 2 mins approx even though there is no water being used in my system. I have checked for leaks and am suspicous that the pressure...
If you have valves at the pre tank you can run it till it shuts down then close the inlet valve and the outlet valve. Wait and see if it goes on again. If so you have a problem in the pressure tank or the switch mech. If not open the outlet valve and wait. If it starts you have a leak somewhere in the house. If not open the intake valve and see what happens. If it kicks on then you have a problem with you check od backflow valve. If this is a shallow well pump it could be in the supply line also. Good luck.
Jan 31, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
The pressure drops very slowly over a month then needs topping uo from the filling loop to 1.5 bar. when the heating is on it goes upto 3 bar. the pipe outside is slightly damp. it was fine during the...
Sounds like the expansion vessel in the boiler has lost pressure or is faulty. If you have a tyre pressure gauge, locate the expansion vessl and check the pressure via the schraeder valve. It should be around 1.5 bar. If there is no pressure you can re pressurise it with a bicycle pump. Should it not pressurise then you will need a new one. The pressure relief pipework outside is damp because the system is over pressurising at relieving pressure at 3 bar. This obviously causes a system pressure drop. You can install a pressure vesel into the heating return pipework should accessing the boiler be difficult.
Oct 31, 2009 | Water Heaters
Water is collecting at the bottom. Where is it
Refrigerators have a defrost water drain that carries water produced during the defrost cycle to the bottom of the refrigerator where it flows into a catch pan. The water is then evaporated by heat from the compressor and refrigerant coils.
Something is likely blocked in your drain system. There is usually a catch basin in the rear of the refrigerator behind the inside lining. From that catch basin, water flows into tubes which usually run down the back of the refrigerator. The drain in the catch basin may be stopped up, or the tube itself could be blocked.
Oct 15, 2009 | Refrigerators
How do I re-pressurise the boiler via the temporary filling loop
you may need to hook a hose to the drain and to a spigot depending on your water pressure in your home and back feed the unit to desired pressur,, does t have an auto matic feed valve or just a shut off valve,,
Jun 15, 2009 | Water Heaters
Changing the thermostat 2000 cadillac deville
The pressure they work within is usualy information on your radiator cap or owners hand book.Your thermostat should be a 180 degree but can vary The 180 is in reference to the heat required to open them so water can flow through and be kept at a more or less constant 180.There are other temp ranges for a wide variety of applications and 180 is the standard one for most vehiclesThe radiaor and water system is pressurised to lower the boiling point of the water The higher the pressure the lower the boiling point
Feb 15, 2009 | 2000 Cadillac DeVille
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
How to re pressurisecentral heating system
Hi tiger650,
I'm Harvey the Master Plumber.
Your problem is: The Alpha SY24 boiler has stopped working. The pressure gauge has dropped, you need to know how to re pressurise the system once the radiators have been bled
Every hydronic heating system is required to have a presure regulator. Most guys call it a feeder valve. Every one I've installed or worked on had one. It's job is to keep the water pressure constant by adding water when you release some air without over filling the system. Sounds like it's not working. Some types can be serviced, others cannont so you may have to replace it. If you're not sure what to do it might be prudent to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Water Heaters
Grohe Chiara Neu Lavatory Centerset  32.362.AV Logo
365 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
