Question about HP LaserJet 1100 Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Runs louder than normal and continuously, BUT will not grab paper and print.
1. Try to print something on my computer
2. Printer turns itself on
3. BUT, it is louder than normal (sounds like a computer fan amped up a lot)
4. Runs continuously, BUT doesn't grab paper and print
ANY IDEAS? Thanks, Fred
  • 42 Answers
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Posted on Apr 22, 2008
SOURCE:
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
Manual feed won't grab paper
If the printer works good when it prints the envelopes/label one by one, I think it works normal (because the paper is not a standard paper).
Mar 06, 2014 | HP Office Equipment & Supplies
I printed a document after which the printer continues to print out blank pages and won't stop. I do not know how to shut it off. I don't even find an off/on button. the small left green light...
Try this solution from Glyph1: http://www.fixya.com/support/t5375375-printer_keeps_printing_blank_pages_non
Chances are it's some kind of software problem. I've had this problem many times in the past, but unfortunately I can't remember how I solved it. Glyph1's solution is sound in my opinion, if you still have problems after that let us know and we can try some other things :)
Jun 16, 2011 | HP LaserJet 1100 Printer
PAPER WON'T FEED PROPERLY. GRABS SEVERAL SHEETS
You need a seperatin pad, sub pad kit and new feed roller.
May 20, 2010 | HP LaserJet 1100 Printer
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
HP LaserJet 1100 does not print gray shadow the printing quality is very bad the toner is full & no problem with it
there is two solutions: 1. your toner cartridge is bad 2. laser scanner unit is dirty - replace toner cartridge - clear laser scanner unit whit dry cloth very carefully you can also clean transfer roller whit piece of paper
Oct 12, 2009 | HP LaserJet 1100 Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
217 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
