Question about Kenmore Freezers
Problems with sears best kenmore freezer model 33207. It makes a chirping sound. Temp is holding at about 8 degrees.
    President:
  • 1,218 Answers
Good day,
Sounds like the cooling fan motor behind the rear panel is failing (bearings going bad). Remove the panel to verify. If so, you will have to replace the motor. Oiling will not work. May help for a short period of time but will go back to the same problem shortly.
Posted on May 11, 2010
Our Kenmore 253.28432801 is just over 5 years old. It stopped freezing, and the Sears tech says it has a leak and needs coils and a condenser. This would be $618, he suggested we buy a new freezer. Co
If it's holding at 28 degrees, it's not the coils. See if dropping the temp does any thing to lower the temp. If it does, fine. If not, most likely just the control needs replaced or just cleaned.
Nov 15, 2014 | Kenmore Freezers
Does Kenmore Elite upright freezer reach -20 degrees celsius, where is the info?
Best way I can answer this is to purchase the right equipment for the job. A domestic freezer is not designed to work like that, although it may get there in temp it won't hold it. Recovery is slower then the industrial unit you seek. Domestic unit warranties are void if used for commercial settings (i.e. lunch rooms, offices, lab's, etc...) I wish I had a better answer for you but if you need a specific temperature get the correct equipment for the job. Good Luck
Jul 31, 2014 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Kenmore upright freezer. continually runs. Temp. is 10 degrees f. I cleaned the dust off the compresser. Checked for leaks on the door seals no leaks. I have just now set the temp control from 4 to 3 and...
Power outages would not make a difference, but dust on the compressor coils would. The best way is to vacuum the coils and then spray with soapy liquid making sure not to spray anything electrical.
Dec 15, 2017 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Deep Chest Freezer
Correct temperature for residential freezer for food is zero degrees Fahrenheit
Jun 07, 2009 | Kenmore Freezers
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezers Logo
142 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
