Question about Craftsman 25cc Gas Line Trimmer
I cant remove the spool to change the line. it appears to be stuck.
    Sniper:
  • 53 Answers
Well there is either a screw knob that must be unscrewed first, or you aren't removing it correctly. Some just Pull/pop right off. Others must be pushed in and twisted (Like a child proof cap) usually in the opposite direction the line spins. Pull the cord a tiny bit to see which way it spins, then push down/in on the spool (its spring loaded) and twist opposite. Most of today's trimmers will give you the spool like that. Putting it back on it simply the reverse action.
Posted on May 10, 2010
  • Ed Gore May 11, 2010
    Try this video link. (Copy and past it into your browser)
    http://www.youtube.com/watch?v=SuGfDNH6f...
How do i remove the spool head? I have line caught in it and cant pull it out as per usual.
Usually you unscrew the end knob anticlockwise to remove the line carrier,or spool
Mar 04, 2015 | Garden
How to change the trimmer line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ii
Jan 06, 2012 | Homelite Mighty Lite Lawn Trimmer
Changing the trimming line on a rlh1100
Dec 31, 2011 | Ryobi Garden
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
I need to put in new string -- don't know how to install. I need to know what to remove -- do I unscrew something, or do I just stick the string inside the casing?
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
Nov 04, 2009 | Black & Decker 14" Grass Hog Xp...
Have Craftsman gas weedwacker double line ran out.
take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Sep 06, 2009 | Craftsman Garden
Echo trimmer with bump feed is not feeding
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Jul 30, 2009 | Echo Garden
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Jun 03, 2009 | Toro Electric Trimmer
Cant get the spool off to change the line
check for 2 or 1 push tabs on the side of the spool that might onlock it so it can be turned too replace string
May 10, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
297 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
