Question about Intertherm P3RA-048K Air Conditioner
The connections on the Compressor keep burning out.
  • 82 Answers
Hello, this is caused by high amps. This means the compressor is drawing igh amps to run. I would check the capacitor to the compressor and check the amp draw of compressor and compare to compressor nameplate rating for amps. It could be the compressor is on the way out....or the voltage to compressor is low
Posted on May 10, 2010
Testimonial: "Yes I agree and it could be what i think it is, debris in the system. The compressor was replaced only 14 months ago."
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore Refrigerators
The air conditioning compressor keeps kicking in and out when on max cool then warms up then kicks back on it's cold when it's working but I can't seem to keep it engaged I've checked the connection to the...
The a/c system is probably low on freon. The pressure sensor sees a low pressure reading on the low side and it turns the a/c off so the compressor does not burn up.
Sep 21, 2010 | 2006 Hyundai Sonata
The wireing harwess keeps burning off from the starter booster to the compresser has been repaired three times after intalled
Hello Check the AMP draw on a running compressor.It should match the value on the compressor tag.It is overdrawing.maybe overcharged system (freon) can cause wire burn.High head pressures will cause it too.
Sep 17, 2010 | Goodman Heating & Cooling
Keeps burning out compressor relays
This is how compressor looks like inside, we took it a part, so we can understand what might be wrong with compressor when it does not work.
Mar 18, 2010 | LG Refrigerators
Compressor keeps running but no cooling?
Check this video, might give you better idea what could be wrong with that compressor. We cut this one open, found couple issues.
Feb 10, 2010 | Traulsen G10010 Refrigerator
Model # CPL J60-1B keeps burning out and
The term "Burn Out" is used when there is acid present in the system, and the acid eats the motor windings coating off, and it shorts out. Air/Moisture in the system causes acid. Burn outs are not always an electrical per sae. When the compressor was replaced, the tech should have flushed the system and also added a special filter/dryer made for such conditions. If that is not done, the residual acid in the system will take out the new compressor. You may want to look into that.
Not exactually sure what you mean by the "Meter Reading" being wrong?
Give me some additional info if you want to persue further.
Dec 31, 2009 | Heating & Cooling
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Wire shorting out
i am not sure if you mean the fan capacitor or the compressor capacitor or both, but whichever one it is connected to is obviously drawing too many amps (if the wiring connections are otherwise good). you may soon find that the compressor or fan motor is dead. this is probably also causing your electric bill to be higher than it should be.
Jun 10, 2009 | Heating & Cooling
We have a Goodman CKL49-1 - 10 Seer - 4 Ton Condenser. One of the wires that fires the compressor keeps burning and, of course, the compressor won't come on. It is beginning to happen every couple of days....
A bad connection in the power wiring, the circuit breaker, disconnect, capacitor(s) or in the compressor contactor (worn contactor) can cause this due to very high resistance and subsequent heat production. If the unit will run, it should be amped checked to trace the cause.
This assumes that the wiring is correct and that the unit was functioning properly before these issues manifested themselves.
Jun 06, 2009 | Goodman CLQ36AR49 Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
223 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
