Question about Microsoft Xbox 360 Console
Xbox games wont retrive help me
How do i get the xbox games from my hard drive to be able to play it again without the game in the console
    Sergeant:
    Champion:
  • 427 Answers
Im asuming that the games you are talking about are preloaded from xbox live. If that is the case, you should only have to got to the purple blade on the dashboard. then click on the memory. Find your storage device. Find your game and click play now.
Posted on Mar 30, 2008
SOURCE:
Hello, when I put a game in the screen says, open
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them, the they may be bad.
May 12, 2010 | Microsoft Xbox 360 Console
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Every time i put a game in my xbox 360 it tells me to open traywhat is wrong?
Hi, Clear the system cache:
2. Select Memory.
You can click the link provide below to check that many have considered this solution as very helpful. http://www.fixya.com/support/t4502977-xbox_360_will_not_read_games_says_open
May 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 will not read games it says open tray or play dvd how can i fix it
2. Select Memory.
Apr 06, 2010 | Microsoft Xbox 360 Console
E 68 error code after i put in a game. please help for the fix
This is an hard drive error, try taking off your hard drive and play a game without it, if that works re-connect hard drive and try again. If this helps remember to thumbs up , if not comment.
Feb 28, 2010 | Microsoft Xbox 360 Console
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
How do i play regular xbox games on an xbox 360 without the disk drive? It says i need a disk drive or hard drive. how????
there is no way to do this. in order for you to play the old games, the console needs to download some file from the internet. so you need a hard disk to store this info.
Dec 05, 2009 | Microsoft Xbox 360 Console
My xbox360 is frezzing
Try cleaning the vents on the console with a vacuum cleaner with the xbox OFF
Then try playing without your hard drive
if it doesnt freeze without the hard drive youve got a problem
ring up xbox
Dec 16, 2008 | Microsoft Xbox 360 Console
Xbos 360 core arcade
This one is cheaper because it comes without a hard drive. It is just the same as the ones with a hard drive but without a hard drive. Yes you can play all the games but it is recomended that you get a hard drive one. You can save games music and game upgrades on it.
Jul 11, 2008 | SNK Xbox 360 Arcade Console
Xbox 360
hard drive not reading game, faulty hard drive, get it changed inc box. this is also a common microsoft fault with this console.
Aug 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
