Question about Intel Motherboard
When i install sound card driver my computer show sound icon for a short time and then it do not work
  • Stelios
    Stelios May 11, 2010
    It do not work (you have no audio at all) or you lost the sound icon? In case of a problem or clarification, don't hesitate to post me a reply. If you are satisfied, rate my solution with the "thumbs". Thanks and regards Please kindly rate this solution Stelios direct FixYa link:http://www.fixya.com/users/technical114
  • 59 Answers
It is not a sound card driver problem , its a virus problem.
so please format your pc or scan it?
Posted on May 11, 2010
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
I formatted the pc and i have problem with sound it is not showing the volume controller and i installed the realtech hd audio manager but its not working
99% of the time this is related to the sound card driver installed. Either you do not have the correct driver or you have not loaded the sound card driver at all for your machine. When you can't see th Audio icon in the system tray (by the time) this means windows cannot see any device which can play sounds.
My advice is to go back to system website (hp.com, Dell.com) look up your machine in there Support -> Drivers area and download the sound driver again. Once installed properly you should see the speaker icon appear in the system tray as expected.
Mar 12, 2011 | Car Audio & Video
My grandad has bought a computer and i tryed to show him how to play a dvd but no sound was playing. I found out there was no sound card? I dont actually know what this means but surely a computer should...
If there is no sound card. Probably it was disabled the sound and maybe there is no really sound card was installed. To make it short buy a PCI sound card, turn off your computer and install the card to PCI slot and turn on your computer and your computer will detect that there is a found new hardware. Ignore it and insert the cd installer and install the driver of your sound card. If it's ask you to restart just restart your computer to update its system. In case that there is a built in sound on your computer check your motherboard model and search for the driver from their official website and download and install, if you download the correct driver it will automatically installed your sound and your sound will be working. Have a nice day!
Jan 07, 2011 | Acer (54.AA806.001) Sound Card
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
My insignia speakers have no sound since I had my new hard drive put in. How do I get my speakers to work
A very common mistake that people make, is to accidentally connect the speaker cable (one with the green connector pin), to the Line-out or Microphone socket on the back of the computer. Just double-check to make sure, this is not the cause of the problem. Make sure that the connector pin color matches the speaker jack color on the back of the computer.
Also, check whether you can see the speaker icon in your Windows system tray (near the clock). If it has a red cross over it, it's quite possible that your sound card (if you have a separate sound card), was accidentally displaced or pulled out of the card slot. This caused sound from working. (If you never saw the speaker icon in the system tray, you'll need to enable it from the Control Panel 'Sound and audio devices'.)
This youtube video may help you install the card properly:
If the speaker icon has a red cross over it, does it show any error message, if you point over it with the mouse? If yes, then most likely the sound driver is missing or corrupted. You can try updating the drivers, other than with Microsoft update wizard, either by manually downloading the drivers from your computer manufacturer's website, or with an easier method as mentioned below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which would scan your computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free driver scanning tool from here or directly from this link (copy and paste the link into your browser, if you can't click it).
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
If, with all of the above, sound doesn't work, you can try with the System Restore. To know more about System Restore, go to this link.
If none of the above methods worked, pull out your sound card and test it in another computer. If your computer doesn't have a separate sound card, try re-installing Windows and lastly try another sound card.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | Insignia 2.1 Speaker System (3-Piece)
Sound doesnt work sometimes when i start up my laptop
1st you uninstall sound driver.and Install driver again.1st of all you check the sound card driver is install in the system.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Sound, Video and Game Controller then
  • See the Audio Driver is in the list.if it is available then right click on Audio driver.
  • Click on Uninstall.
  • After the Uninstall Restart You computer and Install driver again.
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
Mar 11, 2010 | Acer (54.AA806.001) Sound Card
I have a new PC with Vista installed. BA 745 do not work.
check to make sure you have the speaker icon in the bottom right hand corner. If you do, see if you can move the sound bar up and down. This will verify that you definitely have the right sound drivers installed and they got installed properly.
Make sure you have the speakers connected properly. Here is a setup poster to show you how. Follow this just to be sure
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
Once you verify this and the sound still doesn't work then it could be a problem with the speakers or the sound card or sound chipset (if you have integrated sound on the motherboard).
To verify whether its the sound card or sound chipset on the motherboard or whether it could be the speakers. Put the speakers on another machine that you know has the sound drivers installed and turn up the sound bard in the operating system thru the speaker icon. If you get sound then its a problem with your other computer. If you still dont' get sound then the sound speaker system is bad and would need to be replaced.
Jan 14, 2010 | Boston Acoustics BA745 Computer Speakers
I need a sound card for my computer...But i can only down load it on my freinds computer...Can I do that? I can't down load it with my computer couse my modem doesn't work couse of the sound card...
I don't think you are talking about a sound card. You may be talking about a driver. If you are talking about a driver then when dowloaded on your friends computer you could transfere it to yours via usb flash drive or even cd with the driver on it.
Oct 24, 2009 | Dell Dimension 3000 PC Desktop
No sound on my computer
You may not have the correct sound card drivers installed. When you go to Device manage do you see any yellow exclamation points on any of your devices? To get to Device Manager in XP right click on the my computer icon and then select properties then the Hardware tab. You can try using Windows update to see if it can find the drivers, just choose custom instead of express when asked. See if it shows any hardware drivers when it gets done. The other method is to try the manufacturer's website.
If this does not work then post back what model computer or sound card you have and we can troubleshoot further.
May 28, 2009 | Computers & Internet
ERROR AFTER INSTALLING
may i know your sound card pls so that i can find driver for you.
Jan 26, 2008 | Altec Lansing Multimedia Computer Speakers
Intel Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
