Question about Roper FES330 Electric Kitchen Range
Stove keeps beeping F1 E2 every so often cannot get to quit what can i do model FES330kq
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 31 Answers
SOURCE: electric panel on stove displays
check the sears kenmore site they have info on error codes.
Posted on Aug 22, 2009
EllaWatson25
  • 725 Answers
SOURCE: whirlpool stove
We are happy to provide a free diagnosis for your range. If you will provide us with your complete model number, we will be happy to assist you. You may contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM - 7 PM.
We also provide free parts removal/installation instructions for our customers when you purchase your parts through us.
We look forward to working with you and being able to get you cooking right again soon.
Thank you and have a terrific day today. Ella
Posted on Mar 11, 2010
jumptrout51
  • 3361 Answers
SOURCE: my stove has F1 on the screen,and i beeping. I
Sorry it can not be reset.
The F1 code is a failed electronic control. The clock/oven control must be replaced.
Posted on Jul 05, 2010
  • 1116 Answers
SOURCE: Roper Range error code message
F1 - E2 UL A/D error(s)
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Posted on Aug 20, 2011
Why does my hotpoint, electric ignition gas stove beep -F1-
You are having connection issues, or a failing keypad. Disconnect the power. Pull down the control panel and disconnect the thin, flat ribbon connector that goes from the keypad to the control board, then re-connect the power and see if the F1 returns without the keypad attached. If it returns, get the computer board rebuilt at Corecentric Solutions. If the F1 doesn't return, buy a new keypad... Help Me Find My Model Number RepairClinic com
Jul 31, 2016 | Hotpoint Kitchen Ranges
How do I fix my stove?
I would suspect the keypad having intermittent key contact, especially if this is a GE or older Whirlpool wall oven, check by model # on a parts site to see if a key panel is available for it and start there...
Apr 22, 2016 | Kitchen Ranges
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
My stove has F1 on the screen,and i beeping. I
Jul 05, 2010 | Amana ACS7270AS Electric Kitchen Range
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Electric panel on stove displays
Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Roper FES330 Electric Kitchen Range Logo
273 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
