Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Warped Picture & color alignment
I have an RCA HDTV - Model #R52WH74YX51 - the text is white;blue;green;red and out of alignment.
  • mfitzwater May 10, 2010
    I've had to order a new remote 1st. I cannot get to the menu from the TV for auto-convergence to see if this will correct the text out of alignment.
    I've order Remote #R401A2 to see if I can get to this option via remote control.
  • 4,234 Answers
This is a convergence problem. I had a similar set recently that was fixed by resoldering poor connections at the flyback transformer and replacing a blown pico fuse located there as well. I will look up my records to get the specific fuse location and post later.
Dan
Posted on May 10, 2010
Testimonial: "good information - RCA no longer supports the picture tubes and have discontinued this model as well. "
  • RCA Master
  • 3,459 Answers
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
In the middle of watching tv, the tv powered off for a quick second and powered itself back on, when it came on the alignment was off and pictures were warped
Projection sets have two very common problems listed below. bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture is bowed reg green and blue lines on top of monitor.
Projection sets have two very common problems.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Feb 02, 2010 | RCA R52WM24 52" HDTV Projection Television
3d colors around screen
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Feb 01, 2010 | RCA HD52W56 52" Rear Projection HDTV
Hi I have a rca hd52w59. the top half of the
*Screen Looks 3-D
*Colors wont align
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
Picture is blurred, distorted color and panoramic view. How to reset it.
*Screen Looks 3-D
*Colors wont align
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
PICTURE IS FUZZY AND DISTORTED
*Screen Looks 3-D
*Colors wont align
May 26, 2009 | RCA HD52W59 HDTV Projection Television
Ghosting in Red, Green and blue
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Rca rear projection hdtv lost color convergence
*Screen Looks 3-D
*Colors wont align
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
356 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
