Question about Panasonic KX-T7630 Corded Phone
Phone calls are being directed to all lines
Hi their... what it is, is that for some reason ( im not sure if it have been tampered with) but when the phone rings it is ringing to all the phones that are conected with the phone line, it use to just ring to the reception can you help me ?
Regards
Rachel
  • 143 Answers
There must be the problem in the intercom. just reset the whole intercom system and take the help of the operator.
Posted on May 10, 2010
When trying to call. I get "emergency calls only", same after closing reopening at least 20 times, same after taking off and replacing the batterie.
hello, this simply could because due to two reasons, 1.its either you did not insert your sim card properly into your mobile phone,or your mobile phone network settings is tampered with,if it is tampered with you will have to get the settings done by following the steps below, menu>settings>phone settings>network settings>then you select the name of your service provider there,then click on save.that has gotten the settings done. 2.its either your mobile phone is locked to a particular network and might not work if another simcard is inserted,unless you get the phone unlocked from your service provider,it will not work as supposed.
good luck,
take care.
Jun 30, 2011 | Samsung SYNC SGH-A707 Cellular Phone
Im using the Brother MFC 7820n at a hotel. how do i fax? i've tired 9+1+area code+the number, 9+area code+the number and a few others but nothing seems to work, what am i doing wrong?
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9). Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
Apr 20, 2011 | Brother MFC-7820N Printer
Hi , I have an error on my IBM Thinkpad(type 2647), code 0195, securety hardware tamper detected. I know there is several times used the wrong password. It's about an old computer, from wich I don't have...
security HARDWARE tampering?! Nobody locks down a computer using hardware unless they have a damn good reason (software lockdowns are more common); its very expensive to purchase additional security hardware. If you don't know what you're doing, call IBM. They'll guide you through it. If it says hardware tampering, i can't help you because that may mean you have a non-standard setup.
Feb 04, 2011 | IBM ThinkPad T30 2366 Notebook
When I try to make a call from my LG Neon a message pops up and says "emergency only" My LG Neon is also prepaid. I don't know if that will affect anything
Hi,what makes a phone displays emergency only is only when the phone network setting inside the phone has been tampered with or the network signal of the line you are using is failing.
Also it can be caused by panel of the phone (hard ware problem).
When you trouble shoot those areas, you will find out a solution.
Take care.
Aug 06, 2010 | Cell Phones
Pro 42CC 2 Cycle Chainsaw, 18": i can't figure out how to adjust hi low settings d...
They are called "tamper proof" or "tamper resistant adjusters. Amazon has a pretty good set for a reasonable price. Search on Tamper Proof Tool. It's nice the have a set around as you never know what you will run into.
For the Poulan, go to eBay and search on "Poulan Craftsman Walbro carb adjusting tool". You will find what you need there. I hope this helps.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can't make outgoing calls
Hi, have you checked from your service provider that you have an outgoing service? Any number of problems could cause you to lose outgoing dialling, and some of these causes are outside of your control. In my opinion, I would first try a different phone; plug that into your line and see wether you have the same problem. If you do, I would first check your immediate surroundings to make sure that nobody has tampered with your line. Secondly, get your Telco to do a line test; they may charge a smal fee for this, but this depends on region and of course your provider. Might also be advantage too check any other connections and microfilters if you have those. If you have a broadband line, then consider unplugging your computer and router from the phone line and do the test by the main socket with just one phone. More sockets? check these one by one. This is the best way, and the most secure, may save you a lot of time and aggro in the future, and lets face it. If it is the handset, they are cheap enough to replace, but test your line first because this is more expensive and time consuming.
I hope this is the fixya for you, and best wishes in resolving this issue.
yours sincerely
oz
Feb 23, 2010 | Uniden Cordless Phone
Cant connect to vodaphone uk from my LG prada phone!help!!
i have the prada lg and for some reason cant connect to internet..not sure if one of my kids have tampered with the settings.. says network failed. please help!!!! thanks ruth
Sep 04, 2009 | LG Prada KE850 Cellular Phone
Panasonic KX-T7630 Corded Phone Logo
48 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
