Question about HP Designjet Z6100 InkJet Printer
Paper skewing during printing - what do I need to do?
  • 43 Answers
Hey.
Try to use another (new if you can) paper - sheet (A3 or larger), not roll (is cheaper to buy :) ).
The reason for skew could be from moisture on paper or an obstacle in it's path.
Pay atention on the vacum area - the area where the paper is sucked down to be retained for printing. If there are any caped holes, clean them.
If you cannot solve this problem, call the HP service. HP has onsite free service around the world inside the warranty period.
Posted on May 10, 2010
Testimonial: "Great! thanks for the advice. Good site"
The paper does not feed correctly, the print starts and the paper either does not move or goes skewed. The paper rollers keep spinning but no paper reaches the print head
Let the printer skew the paper. Now pull it back out very very slowly. Observe the leading edge of the paper. There will be a "Nick" in it.
Offer the paper on top of where it feeds into the m/c. the nicks position will indicate where the foreign object is that fell into the feeder. Try and remove it or turn the printer upside down and shake it. Hope ink does not pour out of it.
Jan 26, 2016 | Kodak Esp 3250 All-in-one Inkjet Printer
Paper keeps creasing during printing. have moved guides out as far as they go
Creasing is usually caused by pare skewing so guides must be as tight as possible against the paper if it's still a problem you will need a new fuser a unit more than likely
Mar 12, 2015 | Kyocera FS-3140MFP Plus Black & White...
Paper train not level
what do you mean not straight?? the document come out skewed? if so check the rollers for that draw also might be something in the paper path the paper hits causing it to skew
Mar 02, 2014 | Konica Minolta Magicolor 2530 DL Laser...
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
When I print something on my hp 6210, the words and pictures are bisected and skewed. Why is it doing this?
You may have a paper path problem, if the paper skews during printing you will get skewed lines, try cleaning all the paper path rollers you can access, look for any paper debris.
Jan 03, 2010 | HP OfficeJet 6210 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP 4250 - always prints askew with left margin at bottom approx 5mm greater than at the top. Any help greatfully received. John
It sounds like the paper is skewing as it is picked up by the roller - watch a sheet go through and see if thst is the case. Make sure the paper guide in the paper tray is pushed solidly to the left edge of the paper and check if it is loose. If it is loose then it might allow the paper to skew as it feeds in
May 09, 2008 | Office Equipment & Supplies
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
HP Designjet Z6100 InkJet Printer Logo
253 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
