Question about Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U stopped in the middle of a movie. NO blinking lamp or temp light. I checked to see if power was coming into the unit - it was. I checked the filter - it had dust on it so I cleaned it. That did not fix the problem. I let the unit rest over night. This morning I powered it up and there was a slow flashing green and yellow STAND-BY LIGHT along with a quiet sound from the lens/iris area. Any idea on what I can do? BTW, I replaced the lamp two years ago; it should still be good.
  • Panasonic Master
  • 13,433 Answers
Hey
What you have there is the projector is preparing for projection, let it prepare for 5 minutes or so, it should turn on by then, it might be a powersupply issue, So you replaced the lamp 2 years ago, so I take this is about 4 or 5 years old? some of the components, possibly capacitors (often first to go out) might need to be replaced.
basically if the unit doesn't turn on, wait 5 minutes, unplug, wait 5 minutes, plug back in and turn on, wait 5 minutes, if its still not turning on repeat once more.
After that I personally would start taking the projector apart, the lamp I suspect is good, take it out first so that you don't accidentally break it, if your going to open it up.
When you get the projector apart, check all the capacitors that they are flat, stay away from the 200-400 volt big one.
How to get the projector apart.. Start by removing all screws in the unit, check for hidden screws under soft objects, labels, possibly covers as well. casing may be hold together with plastic clips that you can open / release with a plastic stick or a case opening tool often used with cell phones. Or a flat head screwdriver if you don't care if the plastic gets a bit banged up.
if any of the caps is not completely FLAT on the top, it would need to be replaced as it might be the issue why its not powering on properly.
you need to carefully inspect the surfaces of the caps carefully as its not always easy to spot a faulty one.
Another option, if you don't wish to DIY is to take it to a repairer. as this is something that won't get solved by pushing buttons.
Posted on May 10, 2010
My new lamp from Opto Lamps has a plastic tab on the top stopping the cover from closing, do I have to brack this off?
I had the exact same issue with my new Panasonic PT-AE700u bulb. I contacted the company I purchased it from and they authorized the removal of the tab. I used my Dremel tool to slice it off and the bulb ended up working like a charm.
If everything else fits fine...the door just doesn't close, check with the company you purchased the bulb from and see what they recommend. This sounds like a common issue with "OEM" or "Original" bulbs these days.
Oct 07, 2010 | Panasonic PT-AE700E Projector Lamp
Projector will not switch between eco and normal modes
Hi imustafa
Sounds like the lamp may be on its way out... at least is low on output.
May 05, 2008 | Panasonic PT-AE700U Multimedia Projector
How reset panasonic ptae700u when you change lamp thank you
Go into the menu under "Option" and reset lamp hours to zero
Aug 03, 2010 | Panasonic PT-AE700U Multimedia Projector
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
My Panasonic LCD projector has a blinking LAMP light, how do I fix it? Model # PT-AE700U, hasn't ever had an issue before..
Replace the lamp and rest the hours. This procedure is covered in your owner's manual on page 52... If you don't have the manual click here: http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Dec 04, 2008 | Televison & Video
PT-AE700U No Power
Hi ErnieN008
If there is no LED's flashing or even lighting up for that matter , then it could just be the fuse on the Poersupplyboard that has gone.
You can replace this fuse by opening up the top cover and looking for the board with the AC inlet on it.
If the problem however still exists , you will have to replace the powersupply.
May 04, 2008 | Panasonic PT-AE700U Multimedia Projector
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-AE700U Multimedia Projector Logo
74 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
