Question about Makita 12 Volt Cordless Drill/Driver Kit
Drill runs slow with each of two batteries
I don't know if its a battery problem but both batteries fully charged run the drill at the same slower speed.
  • 34 Answers
This can be problem with worn brushes - especially if drill was extensively used. In case drill is new, problem would be probably elsewhere, also trigger can be defective and it does not let all energy go to motor. Juraj
Posted on May 17, 2010
Testimonial: "excellent advice thank you"
  • 5 Answers
It can be a problem with the batteries - if you check their voltage and it is lower than nominal (specified on the battery sticker) - then one or more elements in the battery is dead (each element is 1.2 Volts, so in 12 V battery there are 10 of them). If you dare to disassemble the battery (you'll need rubber/wooden hammer for it, to break glued seams, patience and accuracy), you can replace dead elements (tear off dead ones with pliers from metal buses - remember NOT TO SHORT CIRCUIT BATTERIES !!!, and solder new ones in their place with tin/lead solder, just use a tablet of aspirin as a flux).
Posted on Jun 04, 2010
My child's gator just stopped working. She got on it, it went slow in both gears then, no reverse or 1ST, NOW NOTHING AT ALL. PLEASE HELP. All wires look good.
Jamie, sounds like a bad battery, try and recharge battery. You may have to find a small electronics shop to check battery and charger to verify if they are any good.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 13, 2016 | Toys
How to tell if its a battery problem or the motor is just wore out.
Richard, test your battery with a digital volt meter, charged battery will show close to or over 15 volts, try another fully charged battery, borrow one if need be.
show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Dewalt DC728KA 14.4V 1/2" (13mm) Cordless...
My cordless drill is running at half RPM. Is it the brushes or the motor?
cordless drills have a switch that allows for more torque at lower rpms si in effect it is a 2 speed drill coupled with a variable speed switch that alters the rpms
If the drill is running I would be looking at a speed control problem at this point I would be looking at the torque control switch
Jul 01, 2015 | Milwaukee Hand Trucks Milwaukee Electric...
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 | Drills
I have a makita 8391d cordless drill The problem is that the drill runs incredibly slow even when both batteries are fully charged I have checked the voltage and both batteries are showing the correct...
You have to check the batteries with a new machine. If the new machine works ok then the rotor of the motor of the old machine is broken.
Jan 18, 2014 | Drills
Black and decker drill runs slow
Its much more likely that your batteries are not charging up properly. Ni-CD batteries suffer from 'memory effect' and can appear fully charged when only 70% charged. Also they lose charge when being stored. Do not short them out to discharge them! Wait until the drill complains that they are flat and then recharge them rather than when they first start to slow down. Do not let become completely flat (less than 1 volt).
Mar 03, 2013 | Black & Decker Black and Decker 18V...
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
When do you know the battery is fully chaarged
on the charger there is a red LED that blinks while it is charging when it is fully charged it will not blink usually about 1 hour to charge a DeWalt 18v battery
Jul 04, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a Nextec 12V cordless drill, when i press the trigger, the light flashes, but, the drill does not work. i have tried different batteries and have changed the settings and switches and it still...
At first it does sound like the batteries.
How old is the drill? If it's old, then the batteries may either be dead, or need a careful, slow charge overnight to charge them properly. If new, then they may also need a really nice slow charge.
Sorry to ask, but have you fully charged all the batteries you have tried? !!! Many rechargeables lose a great portion of their charge if they sit for a long time.
Also, when using the drill, never use it until it runs the battery down so far stops, as this can damage batteries or discharge them to where again you need to very carefully charge them to get full charge back again.
Have you overloaded the drill:any plastic smells or have you drilled too hard and stalled it for a long time? That could cause motor damage. But look to the batteries first.
Feb 21, 2011 | Craftsman Drills
I have a dewalt xrp 18 volt cordless drill and the trigger stopped working the battery is fully charged and i tested the motor and its good this is the part number off the trigger 152398-04.
This replacement battery was a great find. We searched for batteries for our Dewalt drill and this is the only site(www.drill-battery.co.uk) that had it and at a good price. Works fantastic and is a great deal.
Jan 13, 2011 | Garden
Makita 12 Volt Cordless Drill/Driver Kit Logo
661 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
