Question about Home
No hot water from electric shower Berry magicoal Action 850
No hot water, power ok. If I tap the top of the water heater tank it works ok. until next time it's switched on.
  • 21 Answers
You need to replace the element probably. you have a short which is a wire touching sometimes then it gets away
Posted on May 10, 2010
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
Nov 25, 2012 | Rheem Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Vanguard 50 gallon electric hot water heater only enough water for about 2/3 of a shower. Used to get enough for 4 showers. Had elements and thermastat replaced. Circuit breaker checked ok. No leaks -...
Replace overflow valve to end the drip.
If tank type water heater has some hot water, then upper element is receiving 240V and electric circuit can be eliminated as suspect.
Lower element or shorted wire to lower part of tank or upper thermostat not wired correctly are next suspects. If plumber replaced the parts the wiring will be correct, but he may not have checked for shorted wire.
If the elements were replaced but sediment was not cleaned out of tank, then that can also cause the problem you describe: the new lower element is shorted out because its stuck in the sediment or no water is circulating around the new element.
Open following links for details how to test and clean tank and test elements:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Rheem Water Heaters
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
Jan 13, 2011 | Water Heaters
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
WATER HEATER ELEMENT IS NOT WORKING NEED TO REPLACE IT.
is there one or two,, turn off power drain it down, use the water heater element wrench remove the wires and the element, install new element snug it tight, start filling the water heater while it is filling reinstall the wires, turn on a hot side faucet only let the air out, wait till you have a full flow of water out of the faucet then turn the power back on to the unit, the thermostat should beat 120 degrees,
Feb 21, 2009 | Select Brands 20012 500°F Heating...
Home Logo
510 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
