Question about Sharp AR-5320 Black and White Copier
Troubleshooting for ar-5320
H and 2 are blinking alternately
  • rinkima Mar 28, 2008
    I am not yet getting the solution, please help me.
  • 168 Answers
H2 is a fuser Error. There should be another 2 digit number that is flashing that is the 2nd part of the error code.
Without the 2nd code I cannot look up the code to narrow it down.
Let me know what the other flashing 2 digit code is and I can give you a more specific answer.
Most likely, you will need a service call to get your machine working again since the fuser unit on these machines are really not made for consumers to remove and repair.
But, there is a slight chance that you might be able to get it working again, so let me know what the 2 digits are after the H2.
Hope this helps.
Good luck.
Mac =)
(please remember to rate this answer if I have helped you. THANKS =)
Posted on Mar 28, 2008
Sharp ar-5320 ch error
Side door open.
-check that all the side doors are closed. ok
Aug 27, 2014 | Sharp AR-5320 Black and White Copier
I want to check toner level on sharp ar-5320 copier, what code do i punch in
press and hold the lighter density key until all red lights blinks
and then press and hold zoom button to display toner level
Oct 07, 2013 | Sharp AR-5320 Black and White Copier
Sharp ar5320 copier
H2 on a Sharp machine is the fusing unit is not heating up. This could be the heating lamp. therimstor, thermal fuse of fuser control.
If you are so inclined, you could test the lamp, and fuse for continuity.
Hope this is of some help.
Ed
May 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
