Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Runs but dies when I squeeze trigger
I have a poulan weedeater. It runs, but when I squeeze the trigger it bogs down and dies. I know that the two little screws on the carburetor need adjusted but I can't seem to find the right adjustment ratio. Can you provide me an answer to go with or perhaps a repair manual?
  • Anonymous Mar 19, 2014
    Poulan p 2500 is starting but the moment i press the trigger it dies down.
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
  • tom turner Jun 09, 2013
    slowly open low speed jet adj. until problem goes away
Carb setting for porlan pro model #115 weektrimmer
Posted on Jun 08, 2010
I have a poulan pro chainsaw it runs fine when choked but when i squeeze the trigger it dies what is wronr with it
It is running too lean, start with the simple things first, replace the fuel filter in the tank, check all the fuel hoses for signs of damage or fuel leaks, replace as required, if all these things are ok, you need to richen up the mixture screws on the carb ( you may need special tools to do this if they are anti tamper screws ) unscrew 1/8 turn on each and try again.
Oct 17, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan 335 weedeater it is six months old it starts with choke but when you press the trigger it bogs down and stalls you can keep it running if you keep the trigger pressed but if you let off it...
If its only six months old i would think it is a carb adjustment issue ( running too lean ) you need to richen up the mixture by un screwing the mixture screws, start with 1/8 turn on each
Jun 30, 2012 | Poulan Garden
Bought new poulan pro PP125e weed-eater and it has an accelration problem. Manual says may need carburator adjustment. Do you know how to adjust?
new --under warranty -- take it in for a warranty service and adjustment
they will know how to adjust it as well as will have the correct tools for the job
Jul 26, 2017 | Garden
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
I HAVE A RYOBI X430 WEEDEATER. IT WILL START FIRST PULL EVERYTIME AS SOON AS YOU SQUEEZE THE TRIGGER IT DIES.
disconnect the exhaust system and run the engine with an attachment until the clog in the exhaust is gone. This fixed the problem for me
Jun 26, 2011 | Sport & Outdoor - Others
I have a Poulan chainsaw that starts, and runs, but when I squeeze the throttle trigger, it bogs, and stops running. Any suggestions as to the problem?
The possibilites are 1. dirt or water in the fuel; 2. filter in fuel tank clogged; 3. main mixture screw set too lean. I am presuming you have the correct petrol/oil mixture.
Mar 20, 2010 | Poulan Garden
Poulan Prolink PPB 330 starts easy, bogs down on high speed
poulan ppb 330 33cc trimmer .idles but no high speed power.
my solution was to remove postage size screen on muffler known as spark arrester and clean. runs great know !
Sep 04, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Shindaiwa model t25 weedeater won't keep running after fuel in squeeze buld has been exhausted
I had same problem, and changed diaphrams, but carb will not adjust or run without choke on. I am thinking control module. $55.95 or coil @ $51.00.
Jul 14, 2009 | Garden
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
1,640 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
