Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Numbers on top-LCE462P-w&D serial # GE14700116 frigidare stack on dryer-problem-dryer buzzer continues to buzz unless dryer door kept open
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Open the control panel and unplug it.
Posted on Mar 01, 2009
SOURCE: Frigidaire GLEH1642FS washer/dryer stacked unit:
The buzzers (there are two, one for the washer, one for the dryer) are behind the control panel. 6 screws must be removed to access the back of the control panel: 2 for the service panel, the 2 outer screws at the base of the control panel, then the 2 much smaller-sized screws.
The buzzers, in my model, are small, un-buzzer-like-looking little black boxes stamped with the brand name 'Ark-less'.
The buzzer for the dryer is connected to 2 contacts on the back of the dryer timer, the contacts labeled 'H' and 'C'.
Once you've identified the buzzer for the dryer, you should be able to find the one for the washer. It's connected by one white and one grey wire.
You should be able to verify this info using the wiring diagram, which will be located behind the service panel. If I remember correctly, the buzzers were labeled 'signal' on the diagram.
Posted on Feb 27, 2011
Testimonial: "Thanks for the info!"
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
MY AMANA DRYER BUZZES THROUGH OUT THE DRY CYCLE, ER? HOW DO I STOP THE BUZZ
www.ehow.com > Home > Home Appliances > Washer & Dryers
YOU MAY HAVE TO REPLACE THE BUZZER. FOLLOE THE SIMPLE STEPS AND , WHO KNOWS YOU MIGHT MISS THE BUZZUNG SFTER YOU FIX IT.
Dec 10, 2015 | Amana NED5100TQ Dryer
No heat for my frigidare fex831cs top load stacked washer dryer
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Maytag dryer problem
most likely you need a new door switch which is located under the top front if you open the door you will see the switch recepticle replace that switch its cheap https://www.google.com/search?q=maytag+dryer+switch&num=100&source=lnms&tbm=isch&sa=X&ved=0ahUKEwju8qXBp9nZAhXLo1kKHVoICLUQ_AUIDCgD&biw=1536&bih=772
Mar 07, 2018 | Dryers
We have a white-westinghouse dryer. serials # wde446jbs1. in the off position the buzzer constantly buzzes, in any type of run position there is a loud humming or muffled buzz. only when the door is...
ok, there is a chance that a wire from the door switch has come loose when she close the door. unplug dryer,take front panel off and check wires at door switch. you may have 3 wires, one on one side and 2 on the other. the single wire is the common, on the other side one is for the dryer operation the other for the end of cycle which can be use for a buzzer or cavity light.
Feb 09, 2011 | Dryers
We have a 80 series elec. dryer, today when the end of cycle buzzer sounded, when door was closed again...buzzer continues to buzz. I can't find a part number, if the end of cycle buzzer needs replacing. ...
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
Dec 28, 2010 | Kenmore 800 6983 Electric Dryer
Dryer wil not run, buzzer does not buzz?
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 20, 2009 | Whirlpool LER4634J Electric Dryer
SERIAL NUMBER LOCATION:
It should be on a sticker on the edge of the dryer door with door open.
Aug 18, 2008 | Frigidaire GLET1031 Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
