Question about Intermec EasyCoder PC4 Label Printer
C4 intermec printer
Green light is on
but not printing lables
plz help
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Posted on May 07, 2008
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
How to stop printer from printing an extra sticker when it prints?
Hi
  • Turn the printer off.
  • Press and hold the green power button and turn on the printer.
  • Release after first flash of led light.The printer will run a test print.
  • Turn it off and then on again.
  • Now print!
Hope it helps.Thanks!
Oct 03, 2011 | Zebra LP 2844 Thermal Printer
I keep getting a Paper Jam message even after calibrating many times. Am using continuous roll of 1 X 4 lables. Was working fine until I tried to print another set of lables. What Gives? Am using a...
2 x possibilities.
1. sensor may need moving to to see label edge (green knob at RHS)
2. possible sensor faulty. Only testable by substitution.
Jul 06, 2011 | Toshiba TEC B-572 Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Empty/pause light on will not print
Intermec Sells a Cleaning Solution that is like a pad of labels, use it and it auto cleans the sensors.
Jun 24, 2008 | Intermec EasyCoder 3400 Thermal Label...
Unable to print Zebta TLP 2844.
When you get a red light it means that there is some type of error, either with the lable or the ribbon.
Take a look at the ribbon and make sure that it is properly placed in the grove otherwise it will 'slip' an wont move.
That is the most common problem that we get.
Feb 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
776 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
