Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Hi. i purchased a whirpool washing machine 3 days ago...and it doesnot seem to work. i set it to a program and when i try to set the water level..i get a beep and the sign dhows as E1 and the machine goes off
  • 269 Answers
Hello, It is most probably either the water valve shut or the hose kinked also check that the drain hose is not blocked also.
Hope this helps.
Posted on May 10, 2010
Is there a way I can change the settings of Whirlpool Washer Model # CAE2743BQ, because this Machine has a very low level of water. Kindly teach us how to make the water plenty in the washer..
If you do not have owner's manual, try manualslib.com Double check the method for setting water level (load size). There may be an "energy conservation or water conservation" mode.
I would also take the purchase receipt to Home Depot and ask for help. If it is all machines, there may be a factory defect. Hopefully, you are within the factory warranty time.
Apr 01, 2015 | Whirlpool Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
I would please like a manual for the simpson eziloader front loader washing machine
45s558e_lr.jpg A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
Aug 06, 2011 | Washing Machines
Whirpool top loader off balance in spin cycle
Your machine is probably not standing perfectly level. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Apr 03, 2011 | Whirlpool Washing Machines
Dishwasher runs about 3 hours
First check the inlet water flow into the machine. There is a strainer attached to this. If it is clogged water filling into the machine will be delayed!
Also check whether using the same wash program as you were doing earlier. There can not be any other fault aprt from this. i presume the wash quality is good.
Heance clean all the water inlet and outlet for free flow.
Jul 08, 2010 | Siemens 24 in. SE25A091 Hi-Line...
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Whirlpool 6245e top loader machine does not spin or wash at all
Hope that no money is required.\
Check the drive belt between the motor and the transmission. If wet or oily or loose, correct the problem and test.
If leaking water, you may have a loose hose fitting, check them with a flashlight while running a test cycle. If not a hose, then a seal (not practical to repair yourself).
FINAL NOTE: DO NOT spend more than 75 dollars to repair a 3 year old or older washing machine. You can buy a used one that works fine for 50 to 75 dollars on Craigs List or other local web site.
Best of luck. -Jim
Oct 21, 2009 | Washing Machines
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
