Question about Moen L3175 Chrome Legend Single Handle Posi-Temp Pressure Balanced Shower O
Moen L3175 faucet with low water pressure
I have a moen L3175 shower faucet. It is a single handle model. All of a sudden the water comes out about 1/4 of the usual pressure. Both hot and cold water is effected. Other faucets in the same room and other rooms are fine. Thanks for any recommendations you have. Faucet is about 11 years old. Is there a kit to maybe replace a sticking valve? The faucet has individual screw shut offs on each of the supply lines. I think that is what they are.
  • 54 Answers
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
Posted on May 10, 2010
What do the 3 screws on the moen L3175 shower faucet do?
Two screws hold the cover plate. Behind the plate on some models you might find 3 screws. The two smaller screws on the left and right side of the valve shut off water to the valve and the larger screw on the right side of the valve is the pressure balance spool. The spool is all one piece.
Sep 06, 2014 | Moen L3175 Legend One Handle Shower Faucet...
Water leaking from handle area (stops when you turn the shower on). How do I get the handle off to get to the cartridge?
Moen model L2175 has a set screw located under the handle or bottom side of handle that you must remove to gain access to cartridge....... Be sure water is turned off and you release water pressure before removing cartridge....... After removing handle there are a few more parts that will need to be removed(scald guard app.) may want to take notice which order you remove these so you want get parts mixed-u p. May-be this link will help you , it is an exploded view of parts and how they are can be removed
http://moenparts.faucetdirect.com/mediabase/specifications/ins162e.pdfp
Sep 05, 2011 | Moen L3175 Legend One Handle Shower Faucet...
How do you remove the Handle on the L3175? There is a recessed "screw" without any way to remove, screwdriver does not fit, it seems to be smooth. There must be a technique I am unable to figure out.
On the underside of the handle there will be a set screw, usually an allen key that will need to be loosened. Once you do this the handle will pull right off. The moen website shows an exploded .pdf view. I found your model by searching with the model name, Legend. http://www.moen.ca/shared/pdf/l3175pt.pdf
Jul 23, 2010 | Moen L3175 Chrome Legend Single Handle...
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen L3175 Chrome Legend Single Handle Posi-Temp Pressure Balanced Shower O Logo
406 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
