Question about Kenmore 74602 Gas Dryer
Everything hooked up but smells like gas. Checked line with soapy water mix. No leaks. What's wrong?
  • mel_15 May 10, 2010
    Thanks for the advice!
    How can you tell if the igniter is bad? Is it like the sound of a grill ignitor, meaning should I hear a click or pop when I turn on the dryer?
    Novelist:
  • 145 Answers
If everything is hooked up and you still smell gas you still have a leak. The gas valve could be letting out gas if the burner is not igniting, however it sounds like you have a small leak on your line which will not be detected by just soapy water. You need to go to a hardware store or a place like home depot and get what's called MegaBubble Leak Detector or a similar brand of leak detector. What this stuff is designed to do is bubble up with massive bubbles where your leak is and it will detect even the smallest leak. If there is no large bubbles there is no leak. Don't be afraid to over do it when putting this stuff on the pipe.
Posted on May 10, 2010
  • gfeck956 Sep 18, 2010
    This same situation happened on my dryer. It was faulty coils not allowing for proper shut off of the gas. Check the coils for continuity when the machine and the coil is unplugged. If they are okay then turn your attention to the valve itself. If you have a defective valve then that would need replacement.
Furnace smells
Mix up a solution of soapy water and spray it around the valve area and watch for bubbles (leaks). If you find any bubbles then correct the problem by either tightening the fitting (always use a back up wrench) or replacing the faulty part.
Dec 19, 2013 | Dometic Refrigerators
Hooked up bbq propane tank and smell gas?
I would turn the gas on and spray soapy water at the fittings if bubbles appear that is where your leak is. if it is leaking in the lines. turn gas off un screw fittings and wrap them with teflon or what some call plumbers tape they are both the same thing and very inexpensive. if it is at the valve on the tank I would get a different tank
Jul 26, 2012 | Grilling
Weber grill replaced hose because of faulty regulator had smelled gas and low cook temp. grill is 4 to 5 yrs old. Connected new hose did soapy water thing no leaks at hose connects. Still smell gas when...
Lisa, when you conducted the soapy water test, how long did you leave the soapy water on each fitting, before you determined there were no leaks? Sometimes, it can take 5 minutes or more for a leak to show up. You should also soap text the tank valve itself.
If no burners were ON when you tested for leaks (and apparently didn't find any), the problem still lies in the Hose/Regulator assembly connections or the tank valve, When you test the tank valve, do it after the valve has been opened very, very slowly (Slow motion, slow).
Hope this helped you to further troubleshoot and solve the problem
Jul 11, 2011 | Weber Genesis Silver B Grill
Trying to address a leak on my Weber Genesis Silver B Grill, I replaced the hose/regulator. Unfortunately, I still hear gas flowing and smell gas if I do not turn off the propane tank valve completely. ...
Mix some water and detergent together - where ever it bubbles that is where the leak is. Sometimes the thread is worn so get some GAS Tape and undo the thread - wrap tape around re-tighten and then check for leaks again with soapy water
Apr 12, 2011 | Weber Genesis Silver B Grill
Is it normal to get a faint gas smell when you hook up you'r gas dryer?
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
Feb 21, 2011 | Kenmore 77632 Gas Dryer
When water heater is off a strong gas odor is present. checked by closing or shutting valve control assembly to off positon, where no gas ordor is present.
You may have a leaking gas valve control. Make up a squirt bottle of soapy water (use dishwasher soap and water) and spray the On-Off-Pilot knob for leaks, as well as the pilot button. Look for bubbles forming. Also check all the gas line fittings and connectors hooked up to the water heater for leaks. If you are smelling gas, do not attempt to relight the water heater. Close the shut-off valve on the gas line and see if the gas smell goes away. If it does, you may have to replace your gas valve. Depending on the age and condition of your water heater, it may be more cost effective to replace the control or buy a new water heater. Reliance is a common brand sold at stores like Lowe's. Typically, parts like your gas valve will usually only have a 1 year warranty. Check the manufacturer decal on the tank to see what their actual warranty period is. If you find a leak on the gas line itself, you will have to turn the gas off at the natural gas meter before disassembling the line to fix it. Use a soft setting teflon based pipe dope for the pipe threads. If you are uncomfortable doing the work yourself or don't know how to proceed, then call your local gas supplier for help. Douglas
Sep 02, 2010 | Reliance Water Heater #6-50-GORT 50GAL...
We just replaced the propane gas line. Our stove is gas and it lights, but neither of our gas water heaters will light. Both water heaters are new and have been working for about 4 months before the...
You have to purge the air from the lines.
At the water heater, take a wrench and loosen the gas line until you smell gas coming from the line. Then tighten the gas line. Check it for leaks with a soapy water solution. Let the gas smell clear, then light the pilot on the heater.
May 25, 2009 | Heating & Cooling
Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Jan 14, 2009 | Heating & Cooling
The smell of gas
call for service immediatly. dont ever mess with a possible gas leak. it is more than likely a slow leak at the shutoff or the safty valve. your local repair company should have a combustible gas detector. to pin point the leak.
Dec 05, 2006 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Kenmore 74602 Gas Dryer Logo
287 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
