Question about LG KU990 Viewty
Battery dies out very quickly. Sometimes, the phone will just shut down automatically.
    Problem Solver:
  • 7 Answers
If the battery is new the software on the phone may be set incorrectly.
Posted on May 14, 2010
  • 977 Answers
Batteries (of ALL kinds) have limited lifetime, and it seems like your has reached to it's end!
I recommend you change the battery with a new one.
Proper care of the batteries may help extending it's lifetime. Keep the cellphone in a cooled temp. (if possible) and try no to overcharge the battery too often (means, disconnect when battery's full!).
Posted on May 10, 2010
    Problem Solver:
  • 5 Answers
I think you're not having a battery problem, especially if it's a new phone. I had that same exact phone, and what happens it that it keeps noticing that the battery is dying out, but if you turn it back on, it will show battery again! It's a firmware problem that affects some some LG Viewtys. You can test that if you charge your battery to the max, and it randomly shuts down due to battery shortage, then if you turn it back on, it shows battery, then you have to replace the phone!
Posted on May 16, 2010
    President:
  • 2,761 Answers
It's common, especially in damp/humid areas, for battery contacts to build up a layer of corrosion over time. You may or may not be able to see the corrosion, but it can prevent your battery from fully charging, and cause it to discharge quickly. Before you replace your battery, remove it, wipe the battery contacts and the phone contacts firmly with a clean dry cloth, then reinstall and charge the battery. If this doesn't help, it's time for a replacement.
Bill B
Posted on May 11, 2010
I drive a 2005 Honda Accord. While I'm driving the gauges from the dash board flicks on and off quickly. Sometimes the car completely shuts down while I'm driving. This happened 4 times and is a scary
YOU NEED A NEW MECHANIC ASAP. It is an elecrical problem, you have a sjhort somewhere. Main computer could be bad or need service. Your mechanic probably broke it or shorted it out.
Apr 04, 2014 | 2005 Honda Accord
Samsung Laptop Shuts Down Unexpectedly
It may be overheating. Try using a vacuum cleaner hose on the air vents, that will help to clear the ventilation for the radiator.
Jan 18, 2014 | Samsung Computers & Internet
Idle fluctuates on 1995 f250, sometimes dies, sometimes revs, no apparent vaccum issues, IAC with scan tool reads low voltage issue. Could this be vaccum, charging system, faulty computer? Problem is...
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 08, 2012 | 1995 Ford F250
Why does Van die when you turn the steering wheel?
Engine stall or RPM fluctuates at idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 24, 2012 | 1991 GMC Safari
1995 nissan automatic truck faltering in reverse
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest or others (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to raise the base idle control.
May 30, 2012 | 1995 Nissan Pickup
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
Why my w910i will automatically shut down
may be possible dat ur battery is loose
Mar 24, 2009 | Ericsson Cell Phones
P168 - shut down
try wiping off the connections n hold button down for a min.
Oct 17, 2008 | Dual Electronics CECT P168 Cellular Phone
Battery dies quickly/ device shuts off randomly
ok maybe you have defective battery replace a new one!! and or you have virus inserted to your memory from your loader or loading station.
Sep 14, 2007 | Philips HDD1630 MP3 Player
Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Jul 25, 2007 | Motorola Mobility RAZR V3
LG KU990 Viewty Logo
465 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
