Question about Cycling
Saavedra rims originally came with a special nipple washer. I have 4 tubular rims without the washer and have used standard nipple washers on 24 hole rims for a set. I used double washers on the drive side. Will this be reliable on their 280 gram rim?
  • 1294 Answers
SOURCE: Suds get stuck in the rubber rim of the washer
You are not supposed to use suds, use 'washing powder' for 'front-loading washing machines' which is available in any supermarket.
Posted on Sep 30, 2007
  • 274 Answers
SOURCE: Washer Probem.. the rubber came off the metal rim.
The rubber is most likely damaged and needs replacing. They make and sell repair kits to fix this. Buy the repair kit from any Bosch dealer and the instructions are included in the package.
Posted on Nov 24, 2007
  • 38 Answers
SOURCE: BMW 325I
 I think you are talking about the speaker grille.  Which is the cover for to protect the speaker and not actually the speaker. You would have to remove the door panel to see the speaker, unless trhey are aftermarket speakers.  In which case a stereo shop would have these.  If it is a stock speaker.  Then this is part of the door panel . Try a auto dismantler in your area.
Posted on Jan 13, 2009
tmandink
  • 30 Answers
SOURCE: The washer leaks from the door by rubber gasket on
yes
Posted on Jul 07, 2009
  • 574 Answers
SOURCE: Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Posted on Sep 07, 2009
My garbage does not work.it makes humming sound for few seconds but does not rotate blades.
Use a broomstick handle to see if disposal blades rotate freely
If blades are stuck, use broomstick to wedge blades free.
If blades rotate freely, and motor does not turn on, then garbage disposal is broken.
Disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
Jan 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal motor works but the water will not drain from the sink. What can I do?
You have clog in tubular pipes under sink.
Start at P trap under sink:
Take a photo if necessary so reassembly is easy.
Remove both nuts on p-trap and trap falls loose.
Any tubular pipe that gets moved, has to be taken apart and reassembled.
So move as few pipes as needed to get job done.
Remove tailpiece going into disposal.
Clean out disposal, tubular pipes and trap.
Rubber washers are replaced with new washers.
Plastic washers are cleaned and re-used.
Tapered end of plastic washer goes away from nut.
Clean and reuse tubular pipes.
We always use a good slap of rectorseal on all tubular joints and washers when re-assembling.
This guarantees there will be no leaks.
Use rectorseal on every joint directly on the washer or joint just before putting on nut.
Jan 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a spoon jammed between the teeth, I tried the allan wrench and it turns but does not free the spoon. I also tried the broom stick handle but no luck. Is there a way to release the teeth or loosen...
The mouth of sink open is too small to get vice grips onto spoon.
There are 2 ways to proceed.
1) Put big screwdriver in crack to see if you can make opening wider so spoon comes out.
2) Remove disposal from below and then grab spoon with vice grips.
Instructions to remove:
-Loosen 2 nuts on p-trap, and take off p-trap.
-Don't move other tubular pipes. Any tubular pipe that moves will have to be disassembled and cleaned and reassembled.
-Disposal is attached with steel ring. Rotate ring to remove.
-Disposal will drop down where you can work on it.
If spoon does not come loose, then buy same brand disposal and replace without replacing sink basket.
-Reattach disposal by lifting disposal into place with one hand and use other hand to set ring.
-Ring catches in 3 places. All three catches have to be in place.
-If disposal is too hard to hold while moving ring, then use bottle jack to lift disposal. Be sure to put board on bottom of disposal so jack doesn't punch a hole in disposal.
-Tubular pipe parts have to be cleaned. Rubber washers are generally replaced. Plastic washers are re-used. Tapered part of plastic washer goes away from nut.
-We use good slap of rectoseal on all tubular washers to make sure they seal
Dec 31, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal is about 2-1/2 years old It is now no longer grinding up potato peels and clog every time! HELP--do we need a new one!!!
1/2 horsepower is the lighter weight model, and if you use it heavily, then it will not work like before.
Another thing to consider is whether the water is draining away completely while you're cutting.
If water and potato peels are both present, your p-trap and tubular drain may need to be cleaned.
Let's go through the whole thing: replacement, p-trap, tubular pipes, everything.
That way we didn't have to change out sink basket or move pipes around.
How to replace disposal body: Disconnect both nuts on p-trap. Remove p-trap and loosen tailpiece going into disposal.
If this is your home, you might want new sink basket that comes with new disposal because it looks shiny and new.
On image above, loosen both nuts on p-trap, trap falls loose, and then work on disposal.
Add a comment
Dec 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put too much carrot skins down the disposal , the blades turn but the water will not drain
You have to take apart the tubular drain pipes located under sink.
It will be fun.
Here's some do-it-yourself information to save calling plumber.
Take apart tubular pipes and clean them out.
Take a photo of the drain before starting. Take other photo as needed for facebook.
Once pipes are apart, run water or use coat hanger to clean out disposal.
Not necessary to take disposal out.
1) Tubular pipes connect to disposal.
Each tubular pipe has a nut and washer.
Pipes can be metal with rubber washer.
Pipes can be plastic with plastic washer.
2) Tubular pipes come apart with channels locks
3) You need a bucket to catch the water when you take apart tubular pipes.
Keep towel handy.
4) All tubular pipes that get moved while working under sink have to be taken apart, cleaned and re-assembled. All you do is take them apart, clean them out, clean them up, and re-assemble the same way they came apart.
5) Take a photo of the drain assembly before starting. Always start with the P-trap shown image above. Loosen top nut and lift up nut. Next, loosen tubular pipe that connects to disposal. and see it can lift out of P-trap without moving any of the other pipes. If clog is inside p-trap, then p-trap will have to come off. Try not to move any other drain pipes; any drain pipe that gets moved will start to leak and needs to be taken apart, cleaned and re-assembled.
6) For best results:
After clog is removed,
Clean all tubular pipes and washers before re-assembly. Take photos as you go so you know where each part goes.
Flat part of plastic washer fits against nut, tapered part away from nut.
Rubber washers can be re-used depending on age >> new rubber washers are best.
7) To re-seal tubular pipes first-time every-time, use rectorseal on rubber or plastic washers.
As you are re-assembling, smear healthy amount over entire washer and then tighten the nut.
Wipe off excess on outside of pipe.
Add a comment if you have a problem.
Nov 21, 2010 | Electrical Supplies
I had to take it apart and now I can't seem to figure out how to put it back into the sink without it falling out.
If I understand correctly, your garbage disposal came loose from the sink basket.
The darker blue arrows point to the connector disc.
The connector disc rotates freely when garbage disposal is not connected to sink basket.
The trick is to lift the disposal into place with one hand.
Push up hard while keeping disposal
perfectly flat and aligned with sink basket.
Then use other hand to rotate connector until it catches on sink basket.
Before starting:
Disconnect the tubular drain pipes because these pipes will have to be re-sealed.
The electric wire and dishwasher hose can stay connected
If you are disabled or impaired, use a car jack or bottle jack to lift the disposal ... but go slow and don't lift the whole sink.
Now to reconnect the tubular drain pipes.
All drain pipes that were moved during the garbage disposal event should be taken apart.
Disassemble these pipes.
Clean the pipes and washers.
If washers are rubber, buy new ones.
If washers are plastic, re-use old ones after they are cleaned.
I use rectoseal on all tubular washers when installing pipes under the sink.
Coat the washers with plenty of rectoseal and the tubular drain pipes will seal first-time with no leaks.
Nov 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Cycling Logo
138 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
