Question about Garden
Where is the drain plug to drain and change oil on a standard push mower
  • 843 Answers
It's under the mower on most Briggs & Stratton engines and others. It's about 2 or 3 inches from the shaft. It may be a bit hard to see because of being caked with grass. Use a putty knife to scrape it off.
Posted on May 10, 2010
Testimonial: "Thank you it is good to find out where the is located. very helpful. "
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How to change the oil in my 550 self propelled push mower. Where is the oil plug? How often does the spark plug need to be changed. We've had ours nearly 2 years with lite use, and no maintenance.
There is no drain plug on that model , one has to lift up the entire machine ,tilt and drain the oil out of the filler spout. Change plug once a year - Champion# J19LM
Sep 10, 2011 | Poulan Pro " Pro" Self Propelled Mower
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
Cannot get started after has started all summer changer spark plug and cleaned air filter Only problem is that also overfilled oil reservoir will that keep it from starting? If so how can i get some...
Hi pt--
If you are certain the oil is overfilled, then yes, this should be the problem. Single cylinder engines have little tolerance for excess oil in the crankcase. Since you're at it, you may as well change the oil in the mower while you have this all apart. In order to do this safely, be sure you have disconnected the spark plug wire from the top of the plug. You do not want the mower to start while you are under it. If you are unsure, ask someone who knows how to do this safely. You should also do this on a cool mower, as gasoline could leak from the tank or carburetor and pose a burning and fire risk. That said:
To change the oil on a single-cylinder lawnmower:
1) Gather materials.
--You'll need a pan or an old bucket to catch old oil, preferably one that has enough capacity for the old oil while also allowing the mower to be positioned with all four wheels on the ground.
--Some rags.
--A set of wrenches or a socket set.
--Two fresh quarts of new motor oil of the recommended viscosity for your particular lawnmower.
2) Disconnect the spark plug from the ignition wire. You'll see a cable running to the top of the spark plug. Grab it firmly at the boot that sits atop the plug and pull firmly. If it doesn't come off easily, be sure you are pulling at the right spot.
3) Tip the mower either backwards or on its side and look underneath the cutting deck. Be careful, as gasoline may spill from the engine's tank. You should see a small square-head or hex-head plug directly below some point of the engine. That is the engine's oil-drain plug. CAUTION: You may need to rotate the cutting blade to gain access to this plug. Be aware that the blade can cut you and that if the mower starts now it can cause serious injury to yourself.
4) Locate the correctly sized wrench or socket that mates to the drain plug.
5) Using a correctly sized wrench or socket, carefully and slowly loosen the drain plug until it turns freely by hand.
6) Position your drain pan beneath the engine's drain plug.
7) Unscrew the drain plug by hand until the oil drains free. Setting the mower down on level ground with all four wheels will ensure the most old oil drains from the engine at this point. Go ahead and open the engine's oil fil cap at this time, as this also allows the oil to drain freely.
8) When the oil has stopped draining from the engine--usually a slow drip is ok--you can replace the drain plug by hand. Be sure the plug turns freely by hand--do not crossthread the plug as you will create a costly repair for yourself.
9) Tighten the plug snug--NOT samson tight--with the correct wrench or socket and wipe any oil present at the plug or surrounding area clean with a rag.
10) Remove the pan from below the mower and rest your mower on all four wheels.
11) Slowly fill the mower's cranckase to full with fresh motor oil. Often, less than a single quart is necessary. Go slow and do not overfill.
12) Tilt the mower backwards again and check for oil leaks at the plug. You may need to snug up the oil drain plug one more time before the first after-oil-change start.
13) Lower the mower, reconnect the spark plug, and start the mower. Let it run for about a minute and listen to the mower for any "bad" sounds. If you hear anything out of the ordinary, shut off the mower immediately and recheck the mower for abnormalities.
14) Shut the mower off.
15) Check the oil level. You may have to top off the fluid level again, as running the engine tends to let the fluids settle out.
16) Disconnect the spark plug once more.
17) Tilt the mower and check the drain plug one more time for leaks. Snug it up as necessary.
18) Let the mower back down to the ground and reconnect the spark plug to the ignition wire.
You should be ready to mow again. Remember to be aware of any oil drips as push the mower around after a recent change--that may indicate the plug is leaking. There is a great picture of what a mower's drain plug looks like in the link below. Just scroll down to the part where you see the picture labeled 'oil drain plug.'
http://floridagardener.com/misc/tuneup.htm
--Hope this helps, Joe.
Oct 10, 2010 | Poulan "" Push Mower
How do I change the oil on my poulan push mower?
First: Disconnect the plug wire from the spark plug. Safety first. Second, look under the mower deck where the crankshaft comes out of the mower (where blade attaches). Right next to the crank shaft should be a drain plug. Remove the plug, drain oil in a pan, replace plug, put mower back on level surface, and refill in the fill plug on the topside of the engine/deck. Don't forget to reattach the plug wire when you are done.
May 28, 2010 | Poulan "Poulan" Push Mower
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
