Question about LG Electronics/zenith 6710t00008 Remote Control
I have LG 42LG30 15 months old the remote control is very slow and often has to pressed several times before it works and less often does not work at all, can you help ? The set is still under warenty.
    Brigadier General:
  • 3,006 Answers
The rubber keys are moulded as protrusions from a rubberised membrane which is slightly permeable to sweat and grease. Over time this builds up as a corrosive yellow greasy deposit on the reverse side of the membrane which prevents keys from making good contact with the circuit board behind. The process occurs far more quickly if you regularly operate the remote with greasy hands such as is the case if you regularly eat in front of the tv, or if you (or any other user) frequently use hand moisturiser.
There are only two repair options:-
1. Take apart the remote and thoroughly degrease it. The membrane itself can be washed in soapy water but dry it thoroughly before refitting. At best this is only ever a temporary fix.
2. The official fix (and best) is to replace the remote.
Posted on May 10, 2010
Lg DVD codes for dish
wontbstopt,
We only have 3 codes available for an LG DVD player. I have listed them below! If neither of the codes work, let me know and I will assist you further.
Codes: 673, 676, 532
Tommy Faust
DISH Social Media Representative
Nov 09, 2012 | DISH Network IR Remote Control
Want to program dish remote to lg dvd player
Hey bcl9113!
We can definitely get that remote programming to your LG DVD player. As we currently don't have any LG codes the steps below will show you how to Power Scan the code to your remote.
Power Scan:
1.) With the desired equipment on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
AUX Mode:
Press 0 for a TV,
Press 1 for a VCR/DVD,
Press 2 for any other device,
Then press STAR (*)
2.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Hope that helps! If you require further assistance you can post here or email me at thomas.faust@dishnetwork.com.
Jun 20, 2011 | DISH Network IR Remote Control
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
Jul 07, 2009 | LG 47LC7DF 47 in. LCD HDTV
Need the code for a LG brand tv on a radio shack 3 in one universal remote control....
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Radio Shack (15-2147) Remote Control
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG Electronics/zenith 6710t00008 Remote Control Logo
787 people viewed this question
Computer Repairing
Computer Repairing
