Question about Health & Beauty
The electric brake on an old Triumph mobility scooter won't release (lever attached for free wheeling) Looking for remedy or reference to available part replacement/service manuals. Thanks
  • 177 Answers
Hi. I have had a few cases where the brake pad will be stuck to the body with rust if it has been sitting in a damp room. A few taps with a small screw driver has fixed this. Put the machine in free-wheel first.
Does the machine bring up any fault codes, or is it too old for that feature. Possibly the brake unit has a short and has been getting too hot.
Does the brake unit have a micro switch on it? Try removing the brake unit off the motor, but leave it connected to the wiring. This will tell you if anything else is faulty. Leave the machine up on blocks while doing this, so you dont have an accident.
Good luck. Neil.
Posted on May 30, 2010
Testimonial: "Thanks Neil...your'e the first one who knew what I was talking about. Sounds like parts will be hard to come by so no harm in disassembly! I'll give it a try."
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Rascal scooter 245
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
Aug 23, 2014 | Electric Mobility Invacare Pronto M41...
Brake system of a scooter
There is a parking brake lever at the back, but if you're talking about stopping the scooter while riding it, there are no separate brakes.
taking your finger off the power lever turns the electric motor into an electric generator which slows and stops the scooter very quickly.
Apr 24, 2014 | Pride Mobility Products Go-Go Elite...
I have a cosco 57-410 4 wheel electric scooter, seems that the electric brake is not functioning right. Scooter wont free will or run with power on. give an electric break code. Swtich on electric...
The brake is controlled by the position of the fwd/reverse throttle paddles.
There is a pot inside that the paddles attach to..if the pot is not
centred the brake doesn't work properly when the paddles are
released. I had the same problem on my Pride Legend XL..
had to order the throttle pot from MonsterScooter,com.
Installed it myself and that cleared my electric brake problem.
Apr 08, 2014 | Pride Mobility Products Go Go Ultra X 3...
Rear wheel rotate in different directions
This sounds like the electric/magnetic brake has locked.
I have a simmerler problem with my scooter & am trying to find a replacement.
Feb 09, 2013 | Pride Mobility Products Pride Legend XL -...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
Small bar on tiller to make it go forward and reverse broken so no way to control start and stop. Also, free wheel is broken and scooter moves when in stop mode or key is removed. can I still use it,...
Hi. Are there other faults as well? Maybe you should get another quote from a different technician, or ask him if he has any second hand parts available.
If you use it, and you cant control it, you end up down a bank or under a bus.
What brand and model is it?
Sometimes the brake disc in the brake unit splits and allows the machine roll on. Sometimes the brake lever has had a bump, and just needs to be pushed back into place properly.
Try contacting the authorised service people for this scooter, and get some prices from them. Good luck. Neil.
May 13, 2010 | Electric Mobility Mobility Electric Power...
I canot pull the lever to disengage to a free wheel
Your brake my be locked up due to corrosion . Take scooter and tilt it up so you can see under it and take spraw lube and spray where the lever goes into the brake assy then work up down or back and forth and it should lossen up
Mar 02, 2010 | Health & Beauty
Health & Beauty Logo
211 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
