Question about Olympus FL-50 TTL Flash
Can I get a replacement repair kit to replace the bulb myself in my fl-50 flash
    Brigadier General:
  • 3,006 Answers
In short, no. In view of the extremely high and potentially fatal voltages which are in a flash even when turned off, repairs by untrained and unqualified persons are strongly discouraged. Olympus and Panasonic will not supply these parts except to dealers and repairers. You can get them from unoffocial sources, but the flash tubes may not be within official tolerances and so you end up with a flash which permanently over or under exposes.
Play safe and leave this to a pro.
Posted on May 24, 2010
Lamp replacement
Its easy...just buy a bulb from sites like Tv Repair Kits and swap it out. To do that remove the back bulb cover, pull out the bulb box....remove the old bulb and put the new one in.
Jan 22, 2013 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Olympus fl-50 powers up but flash does not fire / work
I have the same problem, I have looked every where even on the Olympus site and have no luck finding anything, I paid £280 pounds for this unit and have hardly used it. Took it to a few repair center's & they reckon £200 pounds to repair it (how can that be) I only want it repaired and am sure it is the bulb I don't want to buy a new one this could happen again at great cost to me. I have to say I am not very happy with Olympus at all, bad service, & lack of help with this problem.
Jan 17, 2009 | Olympus FL-50 TTL Flash
FL-50 Repair
Here is the part that you need.
http://www.uscamera.com/cgi-bin/cart.pl
It will take some fiddling around with very small parts to get that installed.
Or you can send it in to Olympus- I know a couple of people that have been charged ~$50 for the repair and Olympus also reconditions everything as well.
Cheers.
Aug 28, 2008 | Olympus FL-50 TTL Flash
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Olympus FL-50 TTL Flash Logo
580 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
