Question about Dryers
Hi. We have a Defy autodry machine. When plugging in the machine and switching on, the power light displays but nothing happens. ie, the machine does not operate even when changing the timing settings. What is the problem ?
  • russell869 May 10, 2010
    So what would you suggest?
    President:
  • 2,468 Answers
Depending on the wiring of the unit it could be a lid safety switch,a bad mechanical timer or timer motor if the timer clock doesn't advance when set,a defective or broken wire at or near the motor start relay due to corrosion from internal machine moisture.
Posted on May 10, 2010
  • danny Hendrickson May 10, 2010
    first being safe unplug the unit,then jumper the lid switch(bypass it),then see if this is your problem,if not does the timer advance by itself?if not then check for power to the timer clock motor that advances the timer through its cycles next
Defy autodry trouble shooting
Check the door latch. If that is faulty, the machine just remains in limbo until replaced. If you close the door and try and select a program and it wont proceed, normally means door latch is faulty.
Jul 03, 2014 | Washing Machines
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
Defy autodry, comes on timer works but will not tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
Loaded washer and then a FH message came up and then I unplugged it. Checked it plugged it back in and no power no lights no nothing. Plug is good and checked house fuses but still no power.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You'll have to Press PAUSE/CANCEL twice to clear the display. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
The machine (Automatic Breadmaker SD-255/SD-254) is plugged in and the display lights up but when I press the buttons but nothing happens - I cannot change the setting or start the machine.
Plug the unit in at the power outlet. If the display comes on, switch it off with the START/STOP button. After the display goes off, switch the unit on with the SELECT button. Remember that the START/STOP button is only used to start or stop a specific program.
Aug 02, 2008 | Kitchen Ranges
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
Dryers Logo
99 people viewed this question
Top Dryers Experts
