Question about Dell 3100cn Laser Printer
DISPLAY SHOWS "LOAD TRAY 1 LETTER
I HAVE TRIED ALL SUGGESTIONS IN THE TROUBLE SHOOTING SECTION OF THE MANUAL, RELOADER THE TRY SEVERAL TIMES, NOTHING SEEMS TO CORRECT THE PROBLEM
    President:
  • Dell Master
  • 2,017 Answers
You ned to set the page size in tray like adjust the tary and set to according to page size.and when you give the print out choose the proper size and default tray.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on May 10, 2010
Brand new arctic king 15000 btu. 1 week after purchase the control panel not responding, manually or remotely. It is stuck as picture shows. Is there a reset button or what would you suggest?
as it is new and still under warranty I strongly suggest that you do nothing other than to get a service technician out for a warranty service
there would have been a user manual with the equipment and a reading of the trouble shooting section may help with an answer
Jun 16, 2016 | Televison & Video
What is the problem when the display keeps on showing Tray 1 load ltr on Lexmark c500
Load ltr means to load letter size paper. If its saying try 1 load ltr - its saying that you are out of letter size paper in tray number one of your printer.
Aug 27, 2011 | Lexmark C500n Laser Printer
My read out says check paper size, when i reload tray all it does is print out an old fax. I have letter in there and have gone though the trouble shooting in the manual.
Did you try clearing your remaining jobs? Fax, menu, arrow down to #2 (fax), menu, arrow down to #6 (remaing jobs)....
this helped me.
jb
Apr 27, 2010 | Brother MFC-9420CN All-In-One Laser...
Hp photosmart D7560 printer i'm haveing a problem with loading paper in very bottom load tray.the printer sceen says to load paper into tray or there is no paper in the tray. i"am using 8 1/2 x 11 inch...
Make sure the paper tray sensor flag has not been dislodged. Look up inside the tray area and also if the back door area opens up, check in there. The flag should move freely>
Dec 30, 2009 | HP Photosmart D7560 InkJet Printer
My washer flashes "h" and "f" then stops.
1st, unplug the washer from receptacle. Wait one minute and replug. This will (in many cases) reset the logic board because of some fault it sensed while the machine was running. Now try the machine to see if it operates normally. If still not working, look in your instruction manual to see if there is a section that shows problem (fault) code letters. Some manuals show this info and some do not. If you see a trouble shooting section, it ma y have this info. See what fault code letters match waht flashes on the machine.
Most codes are for imbalanced load while spinning, water inlet valve interuption, overload of machine (too much clothes), power interuption (temporary loss of power while operating, overfill of water level (again usually do to too much clothes or too much detergent suds), a backup of discharge water. If disconnecting power & reconnecting does not reset the machine, check each of the possible problems mentioned. If still no results, you need a service tech visit. Good luck. Macgivor
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Photo tray issue
Also have this problem, my hp6180 is only 13 months old. Trouble shooting at HP couldn't help me and suggested I buy a new printer. Nothing will print at this point.
Jan 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Dell 3100cn Laser Printer Logo
401 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
