Question about Compaq Presario 5000 PC Desktop
Usb not working
My usb port is nt working ...it is not detecting any device (keyboard or mouse and etc).when i look for the problem in the device manager it is showing that driver for the usb hub is missing ,,plzz help me as soon as possible
    Scholar:
  • 160 Answers
Hello
check that the USB Port is connected correctly plugged into the motherboard
For your OS first install the latest Service packs available
Re-install the USB2.0 Drivers
Connect the KB and mouse to the corresponding USB's
Restart the system.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 30, 2008
    Genius:
  • 1,913 Answers
Hi
what is your os.
try this
install inf update utility for your bord.
install intel chipset installation utility.
Posted on Mar 28, 2008
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
Hi there, my computer cant detect my wireless mouse, even thou the curser is in the screen. but it can detect my keyboard. i did change battery, plug out the wireless antenna, keep pressing the connect...
to know if your windows keyboard and mouse controller is working try to use first a cabled keyboard and mouse, if you find it working try this steps.
first, try to remove the wireless usb device which your keyboard and mouse is connecting to, try to use another usb port from your computer.
second, your wireless device comes with a cd installer, try to reinstall the program of your wireless device
and then try again
Jan 05, 2010 | Computers & Internet
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
NXTECH NOMR ( USB Retractable mouse) is not
Go to my computer proeprty then hardware then device manager.
Then uninstall all usb driver then restart your computer then check.
then if your usb mouse not works then check your usb ports works fine also try your mouse in another computer if it not works then you need to repair your mouse.
Aug 24, 2009 | Computers & Internet
No mice work on my computer!I installed a wireless mouse, and now no mice work, the wireless, and normal keyboard does. How do I fix the mouse socket?
if it is PS2 then you need to reboot your computer in order for the computer to detect the PS2 device ( the PS2 device needs to be plugged in before rebooting )
If USB then try a different USB port and also check bios settings to ensure all usb keyboard and usb mice settings are all enabled.
You could go into device manager and delete usb hub etc and let windows re detect and re install otherwise go to
http://www.usbman.com/WinME%20USB%20Guide.htm
His site has lots of other useful info
May 10, 2009 | Socket Communications Standard Keyboard...
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Flash disk comes up as unknown devices
Try to download some new USB drivers, or update your old one. That may fix your problem.
Sep 05, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My sony VGN N220E does not detect external devices
Try reinstalling your usb ports.
1. goto desktop, right click on my computer and press manage.
2. goto the device manager, find the usb devices / ports.
3. Make sure you are useing a ps2 mouse / keyboard since if your mouse/keyboard is connected to usb they will stop working untill your pc is restarted and the devices are reinstalled.
4. Uninstall all usb devices.
5. after all usb devices are uninstalled reboot the pc.
If the problem is with your drivers ( your pc detects the mp3 player but no drivers found) Download the newest drivers for your product and operateing system from the vendors website.
Nov 30, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
